StangSuspension.com Your source for late model Ford Mustang suspension parts and performance!
MM Solid Motor Mounts
Old Aug 21, 2006 | 05:54 PM
Darkhan's Avatar
Darkhan
Default MM Solid Motor Mounts
What are the advantages / disadvantages of using MM Solid Motor Mounts?
I had to remove a heat shield from the passenger side motor mount due to rubbing on my headers. I'm wondering what a different motor mount would do for me.
Old Aug 21, 2006 | 09:09 PM
STANGSUSPENSION's Avatar
STANGSUSPENSION
Former Sponsor
Default RE: MM Solid Motor Mounts
If it is a daily driver, I'd go with Polyurethane motor mounts.
Solid motor mounts obviously absorbe and transfer all engine vibrations and torque to the frame, which transmits to your seat... not the most comfortable situation for a daily driver...
Advantages: better power transfer to the drivetrain, higher power capabilities (mounts cannot wear due to high torque)
Disadvantages: vibrations and torque are transferred to the entire car...
Here is a link to the Urethane motor mounts, which may be a better option http://www.stangsuspension.com/store...idproduct=1135
Sincerely,
Old Aug 22, 2006 | 02:07 PM
Darkhan's Avatar
Darkhan
Great info, thanks!
The Prothane motor mounts look to be a little thicker. If that is true I am wondering if that will provide more clearance for my headers.
Old Aug 22, 2006 | 08:43 PM
STANGSUSPENSION
Former Sponsor
It may provide a slight difference, but not enough to make too much of a difference...
Its more the material than height....
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
logan409
Sep 26, 2015 07:43 PM
