Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
350z?
Old Mar 1, 2006 | 07:46 PM
757GT's Avatar
757GT
I ♥ Acer
Default RE: 350z?
ORIGINAL: TommyV8
You have an auto? I've been told that auto Mustangs are noticably slower than manuals. A manual 350Z is definitely a 13 second car. If he can drive it should be a good race, but I will give you the edge due to torque and horsepower.
I don't know about them being a 13 sec car. The fastest I have ever seen 1 run is 14.3@96 with a 2.0 60ft. They only dyno in the 240 range with the manual. I beat one bad from a roll in my 04 GT auto. It ran 13.8@101 with my mods. I put at least 3 cars on the one I ran with that car. An auto mach runs at least 13.80s.
Old Mar 1, 2006 | 08:14 PM
JT76's Avatar
JT76
Default RE: 350z?
i thought 350z's were meat for 99-04 GT's and no contest for Machs.....
Old Mar 1, 2006 | 09:08 PM
nhazra's Avatar
nhazra
Default RE: 350z?
You have about 40lb-ft more torque and 23 hp more than him (the track editions have 300hp). He also weighs close to 250 lbs lighter than you. I still think that you have more of an advantage than him. From a dig you should have the edge. I have the G35 and because of IRS it's hard to launch them. From a roll I surmise that it would be closer. In the end you should win although it'd be closer than people think.
Old Mar 1, 2006 | 09:12 PM
SpecterGT260's Avatar
SpecterGT260
Default RE: 350z?
ORIGINAL: 757GT
ORIGINAL: TommyV8
The older ones were running 14 flat as tested. the new ones have 300 crank hp. they are a little heavier I think and actually, they arent much lihgter than the mustang.
Old Mar 1, 2006 | 09:23 PM
Guest
Guest
Posts: n/a
Default RE: 350z?
Stock for stock 350Zs are fair game for a 99-04 GT...
I wonder just how many times I've said that.
06 350Z weights:
350/Enthusiast/Tour/Track/Grand
Manual transmission 3,339 3,346 3,400 3,370 3,404
Automatic transmission N/A 3,344 3,380 N/A 3,391
Weight distribution 53/47 53/47 53/47 53/47 53/47
MT equipped cars make 300/260 hp/tq
AT equipped cars make 287/274 hp/tq
Just keep in mind that the Tour/Track/Grand models will outhandle the living hell out of any 99-05 GT... that's the main reason the car is built with a near perfect 53/47 weight distribution.
Old Mar 1, 2006 | 10:49 PM
TommyV8's Avatar
TommyV8
Default RE: 350z?
The 350Z has been driven to solid 13 ETs, it's been documented. How fast is an auto Mach 1? How much will a cold air intake and tune help? I still believe the Mach should prevail, but if the 350Z driver knows what he's doing then it shouldn't be a cakewalk.
Old Mar 1, 2006 | 11:00 PM
ByPopularDemand's Avatar
ByPopularDemand
Default RE: 350z?
ORIGINAL: antiv6
would i have a change against a stock manual 350z that is manual. My car is auto
Hes gonna get you if you miss a shift...no you have an auto... as long as its in D you got it
Old Mar 2, 2006 | 12:31 AM
Bullitthead's Avatar
Bullitthead
Default RE: 350z?
Put me in with those who say it should be close, but I'd give the Mach I the edge. Race him from a dig if at all possible...
05zexstang
Oct 25, 2007 10:06 AM
5.0shelby
May 9, 2006 06:47 PM
Voodoo
May 3, 2006 11:34 PM
ZBoy
Dec 16, 2004 06:19 PM
UT04GT
Sep 6, 2004 04:45 PM
