Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Track Tricks
Old May 1, 2006 | 05:20 PM
JT76's Avatar
JT76
Default Track Tricks
I read some of the stickies at the top and got some good info for going to the track. Anyone have any other helpful tips for me? A few of the mustang guys take off their headlight to get more air in, is this a ricer trick or does it actually work. Also i dont have DR's yet so im running on a pair of stock street tires off an 04 Mach 1, in other words stock tires. Should i let some air out to Hook better? what PSI should i run at? Any other advice is welcome thanks guys
Old May 1, 2006 | 10:37 PM
JT76's Avatar
JT76
Default RE: Track Tricks
anybody?
Old May 1, 2006 | 10:46 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
STAY OUT OF THE WATER, I can't stress that enough. I would only drop down to about 25-28 psi in the tires. Personally I don't think the head light thing does anything. Also don't do a big burn out on the stock tires, only do enough to clean the tires off.
Old May 1, 2006 | 11:03 PM
JT76's Avatar
JT76
Thanks alot JD,first time i went there i went right through the water, and it resulted in a 3.4 60ft time. Do you think letting a little pressure out of the tire will help at all or is it even worth my trouble?
Old May 1, 2006 | 11:15 PM
Blues Power's Avatar
Blues Power
You can let some out. The stiffer sidewall on street tires makes them more prone to spinning. The lower pressure will give you a little more patch.
I tried the headlight removal and it didn't do anything. I'm by no means fast but all passes that day were right on spot with previous trips.
Old May 2, 2006 | 12:04 AM
JD1969's Avatar
JD1969
ORIGINAL: stanggang1892
let out a few psi and it might help you, if you let out too much it will cause the tire to cup and lose traction.
cr620
Oct 3, 2022 10:18 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
CS2007
Florida Regional Chapter
Sep 29, 2015 12:06 PM
mungodrums
Sep 28, 2015 10:54 PM
