Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
mustang vs. eclipse
Old Nov 3, 2006 | 05:59 PM
  #81
OnyxCobra's Avatar
OnyxCobra
Default RE: mustang vs. eclipse
ORIGINAL: MEM 302 5.0L
i know im just saying he got his boost checked awhile back and it was only set at 7 psi
it's slow then, thats way less than stock.
Old Nov 3, 2006 | 06:01 PM
  #82
MEM 302 5.0L's Avatar
MEM 302 5.0L
yep ...sounds like it if its supposed to be set at 14..haha...he bought it for 4,000 bux..from someone who said they modded it out alot ...but hes had alot of people look at it and they all say its just a stock eclipse and ive seen the engine and all, it sucks nto being able to drive my stang....wont get it back from the tran shop for another 4 or 5 days i think.
Old Nov 3, 2006 | 06:06 PM
  #83
88blackgt's Avatar
88blackgt
even if its stock its pushing 14 psi. but its not, because he has exhaust, which helps a ton on a turbo car. i still think you're going to lose even if its stock, even more so if he has exhaust. does he have an aftermarket boost gauge? stock boost gauges are usually shot so this could be the reason for it "only being at 7 psi"
Old Nov 3, 2006 | 06:31 PM
  #84
MEM 302 5.0L
i dont no
Old Nov 3, 2006 | 06:39 PM
  #85
CrazyCobraSpeed's Avatar
CrazyCobraSpeed
i would say u could beat him... i wouldnt bet cash on it hto... and if he can out drive u he mite win just becuz the cars seem rather close... now if he really is running 9 psi and didnt make it up or doesnt kno what his talking aobut then that would we a hell of a lot lets hp since the guys on here are sayin 14 is stock... thats 5psi less... i could easily believe a 25-40hp loss on that... and that would also make the exhsuat less usefully... gears are a hell of an upgrade... and then timing would be next... if you friend has a gun and a dist wrench just do it at his house... takes like 15mins mayb... and if you dad knows very lil about timing he couldnt tell the difference... just mkae sure u using high octance fuel... and let hte motor get used to the timing b4 u push it hard.... gl ethier way
Old Nov 3, 2006 | 06:54 PM
  #86
jaznasy69's Avatar
jaznasy69
ORIGINAL: CrazyCobraSpeed
^^sounds good to me^^
Old Nov 3, 2006 | 07:28 PM
  #87
dr.gonzo's Avatar
dr.gonzo
my convertable 5.0 aod with 3.73 gears ran best of 14.9 I left it in o/d and it shifted into od at around 3000 (way to early) so with a hard top and 4.10's you will prob be around 14.2 to 14.5's the 1/4 mile might be to long to just leave it in drive you might have to pop it in od. here are the stock 1/4 mile times I found.
1989 Mitsubishi Eclipse GS 7.2 15.8
1990 Mitsubishi Eclipse GS-T 7.4 15.9
1995 Mitsubishi Eclipse GS-T (Auto) 7.4 15.5 (MT June, 94)
1990 Mitsubishi Eclipse GSX 6.9 15.2
1992 Mitsubishi Eclipse GSX 7.0 15.3
1992 Mitsubishi Eclipse GS Turbo 6.7 15.3 (MT Sept, 92)
1993 Mitsubishi Eclipse GSX 6.8 15.2
1995 Mitsubishi Eclipse GS 9.0 16.6
1995 Mitsubishi Eclipse GSX 6.4 14.9
2000 Mitsubishi Eclipse GT 7.0 15.4
2006 Mitsubishi Eclipse GT 5.8 14.4
that should make u feel more confident if it is truly "stock" or it is modded and he is pulling a bytch and he is just saying that to win and make 5.0's look bad in front of his friends.
my heavy and weak frame with 3.73 beats every car except the 2006 model and that was my first time at the track.
Old Nov 3, 2006 | 07:34 PM
  #88
MEM 302 5.0L
1/4 mile is gonna be way too short for just D....ive practiced my shifting from 1st to D to O/d and it all happens pretty fast....what is the power band on my engine? just wondering..cuz ive never really looked into it
Old Nov 3, 2006 | 08:42 PM
  #89
5.0GTConveritbleGuy's Avatar
5.0GTConveritbleGuy
Just race homie, and you'll have your answer!!
Old Feb 14, 2007 | 04:22 AM
  #90
onemoreday21's Avatar
onemoreday21
Alright I used to own a 98 GST Spyder, they do push 14lbs. stock and they are quicker than first gen front drivers not awd. There is also no way for him to be pushing under 14lbs. of boost because the wastegate has a set spring inside, when boost reaches that high it opens and lets exhaust gasses bypass the turbo. You can go higher with a boost controller which is basically a check valve which delays boost from getting to the wastegate until a higher boost pressure. So heres what there is to look at, he is possibly pushing 14lbs. or more and is just lying to you in that case your cars toast, he could have something wrong under the hood, bad turbo for one, if this is the case you will most likely see smoke from the exhaust due to him burning the oil thats lubricating the turbo, or he has a boost leak that he doesnt know about. If hes actually only pushing 7 to 9 I would say you have a chance. Its only a 2.0L 4cyl with a 9.0:1 CR I believe. First gens were 7.8:1. Hope this helps you some.
