Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
mustang vs. eclipse
Old Feb 14, 2007 | 04:30 AM
  #91
90mustang5.8's Avatar
90mustang5.8
I ♥ Acer
Default RE: mustang vs. eclipse
why do damn noobs always bring up old threads?[:@]
Old Feb 14, 2007 | 04:40 AM
  #92
OnyxCobra's Avatar
OnyxCobra
lol i saw the thread and i was like, wow that seems somewhat familiar...
Old Feb 14, 2007 | 05:02 AM
  #93
86 5.0L's Avatar
86 5.0L
ORIGINAL: OnyxCobra
me too.....
Old Feb 14, 2007 | 05:06 AM
  #94
90mustang5.8
I ♥ Acer
ORIGINAL: 86 5.0L
ORIGINAL: OnyxCobra
me too.....
i didnt reconize it
Old Feb 14, 2007 | 08:31 AM
  #95
lovemygt's Avatar
lovemygt
ORIGINAL: littlechiztri
[align=center]If u have a V8 and are beat by a 4 banger, then shame on you....SHAAAAME ON YOU![/align]
I got beat by a 3800 CC VWbug at the track in my GT.lol
Old Feb 14, 2007 | 06:33 PM
  #96
Quick Shot xMLx's Avatar
Quick Shot xMLx
ORIGINAL: onemoreday21
Alright I used to own a 98 GST Spyder, they do push 14lbs. stock and they are quicker than first gen front drivers not awd. There is also no way for him to be pushing under 14lbs. of boost because the wastegate has a set spring inside, when boost reaches that high it opens and lets exhaust gasses bypass the turbo. You can go higher with a boost controller which is basically a check valve which delays boost from getting to the wastegate until a higher boost pressure. So heres what there is to look at, he is possibly pushing 14lbs. or more and is just lying to you in that case your cars toast, he could have something wrong under the hood, bad turbo for one, if this is the case you will most likely see smoke from the exhaust due to him burning the oil thats lubricating the turbo, or he has a boost leak that he doesnt know about. If hes actually only pushing 7 to 9 I would say you have a chance. Its only a 2.0L 4cyl with a 9.0:1 CR I believe. First gens were 7.8:1. Hope this helps you some.
If the damn BOV doesn't leak. My old 96 Spyder GST didn't leak and it was was at 12 PSI stock. I've heard a number anywhere from 10-14 stock but it just depends on the car and that POS plastic BOV.
Boost leaks...although you pointed that out later
How did you own a car and not no about it? 8:5 comp kid
Why are you bringing an old *** thread back? Obviously the OP wasn't very intelligent....after 5 pages he never even said what body style it was
Old Feb 16, 2007 | 12:09 AM
  #97
hellas85stang's Avatar
hellas85stang
if ya have a newr 5.0 and have gears too like ya say..id say the gears will make the diff...yall are both close on the fly hp rating... what stall ya have...what rpm isstall....
prob will beat him on gears and stall...
Diode Dynamics
28
May 26, 2022 12:02 PM
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
yurizx6r
Sep 7, 2015 06:40 PM
daytooday
Aug 11, 2015 09:22 AM
