Could I win??
ORIGINAL: geetee03
if your auto and he is standard you will prolly lose, otherwise you should win.
ORIGINAL: MustangMagic
I always thought the auto had the advantage off line. Some people says automatics are faster than sticks.
ORIGINAL: geetee03
automatics are more consistant, and allow for more precise, but that typically only applies to modified auto transmissions. however, a car with the automatic transmission has a higher drivetrain loss, so a well driven mtx car should typically outrun a well driven auto trans. also, off the line, a manual car should have an advantage, as the driver can bring it out at a higher rpm, which usually allows the car to be in its proper power range.
ORIGINAL: Ride Of The Month
those people are stupid.
ORIGINAL: geetee03
I understand your point, however, on a naturally asperated engine.
not if youre a good driver...thats the exact reason that a well driven sRT4 is MUCH MUCH faster than a poorly driven srt4, because they drop out of the power band...
