Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
What do you shift at?
Old Dec 14, 2006 | 02:15 AM
  #21
WRXtranceformed's Avatar
WRXtranceformed
Default RE: What do you shift at?
ORIGINAL: stanger88
What all the jackass comments, the guy needs help shifting.
Who was being a jackass? So far everyone was answering his questions....
When you shift is dependent completely on your car and setup. Practice makes perfect to find out what works best for you
Old Dec 14, 2006 | 02:20 AM
  #22
Demon 340's Avatar
Demon 340
Administrator
ORIGINAL: MustangMagic
ORIGINAL: 88blackgt
usually shift at like 6200 or 6300, hard to tell in first it revs so fast
you want to shift a little bit after your peak power. after the peak, you are still making pretty good power, and the next shift will keep you higher up in your powerband. try like 5400 or 5500 if it peaks at 5250
First does indeed go by quick. I already hit the rev limiter and messed up a belt.
imagine with 4.56 gears...
Old Dec 14, 2006 | 02:22 AM
  #23
lVlustang's Avatar
lVlustang
WOW! Give the guy a straight answer for god sakes! Shift at 5500.
Old Dec 14, 2006 | 02:23 AM
  #24
88blackgt's Avatar
88blackgt
lol i would have to launch quite a bit lower, or i'd be bouncing it off the rev limiter before i knew what was going on
Old Dec 14, 2006 | 02:24 AM
  #25
CobraSnake's Avatar
CobraSnake
I just punch it look at the rpms and just wait till it almost hits redline then i shift and do it all over again.
Old Dec 14, 2006 | 02:25 AM
  #26
Sleeper05's Avatar
Sleeper05
6400
6200 1-2 to limit spin
6400 2-3 to maximize power band
6200 3-4 to maximize torque, as i cross at 6000 in 4th
Old Dec 14, 2006 | 03:34 AM
  #27
Dingo0079's Avatar
Dingo0079
hey man if it helps I shift mine at 5900 I had mine dynoed too with the #'s in my sig it peaked at 5500 but if I shift at that my times were slower, but with the amount of mods you have, if you are running street tires is all about the launch, I only broke thirteens once last run I have done still trapped the same as I always do but somehow got it out of the hole pretty good. Your car is still making power at redline just not as much plus the higher you let it go the closer you are to peak when you shift.
Old Dec 14, 2006 | 04:13 AM
  #28
geetee03's Avatar
geetee03
5800
Old Dec 14, 2006 | 09:01 AM
  #29
MustangMagic's Avatar
MustangMagic
I ♥ Acer
ORIGINAL: Sleeper05
6400
Sure, this sounds nice. But I have only 1 shift light. So I guess I can set it at 6200 and wait a fractor of a sec longer in 2nd and 3rd.
Old Dec 22, 2006 | 12:08 AM
  #30
YouGiveMeRash!!!'s Avatar
YouGiveMeRash!!!
Around 5600.
