srt-4
ORIGINAL: hawkshaw
Hey where at I have a condo in TX. If you have a street car you might not want to just race anyone. 337hp in a srt will get 11's with a stock turbo. From you beloved SRTFORUMS.
Stage 3 SRT-4's do mid-high 12's, where are you pulling the magical 11's out?
ORIGINAL: hawkshaw
Also if you have the money to burn you can add a few turbos to get your 26lbs but by then you could have gotten a Farrari
To get 26 PSI it costs the same as getting a Ferrari?
Galveston, That is with street tires. With slicks and sold motor mounts they run under. Why did you not read that go back and read some more on it. Slicks will put the 60' times around 1.8 in stead of 2.2 witch translates to a much better hole shot and times. I have 2 friends with stage 3's ones best on an 1/8 crappy track is 7.7 with slicks and 376 hp also not using the shot of nos.
Well to buy a New mustang. Get all new and warrented items installed professionaly and drive any where and have this worked on byany Ford dealer. O you cant. So buy you a Farrari and save the if I had If I ran IF I COULD. Alot of if's. I have I did. I will run 26 lbs when it is ported out and shipped back. What did you say. IF. My car runs on pump gas not ifs.
ORIGINAL: hawkshaw
