Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
tire pressure
Old Feb 17, 2007 | 03:30 PM
qbuswell's Avatar
qbuswell
Default tire pressure
I have 18x10 rims with 295/35 BFG KDW2's and would like to know what psi I should run in them at the strip.....I run about 31-33 on a regular basis for road racing.
Old Feb 17, 2007 | 03:44 PM
TommyV8's Avatar
TommyV8
Default RE: tire pressure
Anything other than the reccommended pressure will reduce the contact patch. I have experimented with this myself at the strip. Increased traction will only be found with drag tires.
Old Feb 17, 2007 | 03:47 PM
qbuswell's Avatar
qbuswell
I lowered the pressure last time to like 24 psi and after 2 runs ran a 14.137 1/4 mile time.......so if I keep the 31-34 psi I could do better?
Old Feb 17, 2007 | 03:51 PM
TommyV8's Avatar
TommyV8
You will probably get a better 60 ft time. When street tires are that underinflated they "cup," so that only the outside edges are making contact with the ground. Just run them at 34 psi like normal. That's where I've found the best traction (or less spin, I should say).
Old Feb 18, 2007 | 02:29 PM
contentsunderpressur's Avatar
ORIGINAL: TommyV8
+1 I've done a lot of experimenting myself with street tires at the track. They do best at the psi recomended for the tire.
Old Feb 18, 2007 | 02:33 PM
JT76's Avatar
JT76
some people think that by droping the pressure in street tires you get better traction at the strip, ihave tried this and my 60 fts went in the tank.....keep it at the street pressure....i could cut some 2.0 60's with street tires when left at street pressure....the way to go is get a set of nitto 555 dr's Bfg's or mickeys (listed least to most sticky in my experience)
Old Feb 18, 2007 | 02:36 PM
ORIGINAL: stanggang1892
The best I got with street tires at 32 psi was 1.94 60 ft. I let the pressure down to 20 and went to 2.20 60 fts. Drag radials are awesome. I have cut 1.71 60s on a set of M/Ts.
Old Feb 18, 2007 | 03:35 PM
Go Blue 48044's Avatar
Go Blue 48044
So much is made of dropping rear psi tire pressure at the track.What's extremely underestimated is over inflatting the front tires.Less drag and better trap speeds.
Old Feb 18, 2007 | 03:52 PM
ORIGINAL: Go Blue 48044
Makes sence. I'll have to try that.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
marc954
Sep 29, 2015 11:18 AM
