Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
LS3 Dyno results
Old Jul 6, 2007 | 06:15 PM
  #71
Sleeper05's Avatar
Sleeper05
Default RE: LS3 Dyno results
ORIGINAL: MrRogers
2008 base model M6 coupe will be in the low 12s high 11s. I love it! I was able to get a picture a GMs LS3 designer..
High 11s is going to be more rare than a GTO in the high 12s (both stock). I venture to guess that a decent driver will put a stock one to a 12.20-12.40 at 115. Mark my words.
Old Jul 6, 2007 | 06:16 PM
  #72
8cd03gro's Avatar
8cd03gro
i don't know what this is supposed to mean...who cares if the ls3 vettes will outrun stock gt500's. I'm still pissed that people even consider them the same class. Just wait until the camaro comes out with the ls3. It will be heavy like the gto, be no competition for the gt500 (the ls3 model, if that is one of them) and be probably 35k so it wont really be in the gt price range. Then whatever the top model camaro is going to be probably with close to 500 horsepower if not there, will probably be right there performance wise with the gt500, but probably will cost a bit more (keep in mind the gt500's are actually going to cost around 42k around that time). The corvettes should not be compared to the mustangs...that's like comparing the gto's to the corvettes, they are a totally different type of car...
Old Jul 6, 2007 | 06:17 PM
  #73
8cd03gro's Avatar
8cd03gro
ORIGINAL: ThisBlood147
Gotta be the trannies and the top end curve. Cuz the M6 is equal to the GT500 in weight and crank hp.......but the M6 has 100lb/ftless torquethan the Shelby. Yet, they seem to pull similar 1/4 numbers.
Keep in mind suspension, weight transfer, gearing, etc.
  #74
C6 VETTE's Avatar
C6 VETTE
ORIGINAL: Sleeper05
I'm fairly confident I could murder a stock LS3 vette naturally aspirated. I would just have to dump a bunch of paper into P/P heads and some aggressive cams, at which point I'd have as much or more rwhp. Unfortuneately, it's not worth $4k to do that, so I will place my bets on traction and driver mod for now!
Your sounding like a GM'er . You put H/C setup as naturally Aspired, but it's still like a Ford guy saying he'll slap on a blower...lol
As you stand now.....Your only chance would be from a dig....A short race at that to stand a chance against an average driver......But I admire your confidence....
Old Jul 6, 2007 | 06:21 PM
  #75
ThisBlood147's Avatar
ThisBlood147
ORIGINAL: 8cd03gro
Well, suspension with better transmission and huge top end apparently. The M6 has 3.62 gearing compared to the Shelby's 3.31's......but with the Shelby's 100lb/ft torque advantage I'd think that the gearing difference would balance out.
Old Jul 6, 2007 | 06:26 PM
  #76
C6 VETTE's Avatar
C6 VETTE
ORIGINAL: Sleeper05
ORIGINAL: MrRogers
Those #'s have been done by quite a few non-professional drivers in a LS2 C6....Allthough I would agree a 12.2 is not easy to get by any means....A 12.4 is an ET that I'm sure happens quite often, as well as 114-115mph traps....
According to the dyno results so far...387rwhp for a stock LS3M6 should be right on par with a LT's,tune.CAI,exhaust LS2......which a high 11 is very managable....WITH A DECENT DRIVER
Old Jul 6, 2007 | 06:41 PM
  #77
Sleeper05's Avatar
Sleeper05
ORIGINAL: C6 VETTE
ORIGINAL: Sleeper05
Is that not exactly what I said though? Aggressive cams in the 3v are good for 25-45rwhp, depending on the source, and P/P heads are good for 35-50rwhp, depending on source. Done together, 60rwhp is a viable expectation, making the first part of my comment correct as well!
As per your followup post:
I have seen a number of C6s at the track and these miraculous low-12s that the GM guys claim simply just don't happen almost ever. I've seen full exhaust/intake ones going 12.50s as a best, and stock ones going anywhere from 12.70s-12.90s best (I'll ignore the douche running 15.0flat CONSISTANTLY in his last time I went out to the track, lmao).
Basically, I would stick with my comment that an 11-second pass bone stock will happen about as often as a 12-second pass for a GTO. I'll bet a beer on it...well, you're in the wine country...so, a glass of shiraz instead.[8D]
Old Jul 6, 2007 | 06:45 PM
  #78
C6 VETTE's Avatar
C6 VETTE
ORIGINAL: Sleeper05
ORIGINAL: C6 VETTE
ORIGINAL: Sleeper05
I should have clarified up to the 60ft...[8D]
Old Jul 6, 2007 | 06:47 PM
  #79
MrRogers's Avatar
MrRogers
ORIGINAL: Sleeper05
ORIGINAL: MrRogers
I think that it will do high 11 ocsasionally. 387rwhp In a 3200lb car will get you there. The LS3 is pushin near 440hp to the flywheel.
Old Jul 6, 2007 | 06:49 PM
  #80
Sleeper05's Avatar
Sleeper05
^ Low Blow (C6 Vette)
Funny story though. On my 12.63 @ 109.8 run last month, I cut an almost perfect light (.010), and a 1.79ish 60', and because of that, was only ONE CAR LENGTH behind at the 1/8th to the cam/superchargedc5 z06 that ran a 11.3 at 122 next to me!
