Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Vtech Kill
Old Sep 20, 2007 | 04:55 PM
  #21
84redfox's Avatar
84redfox
Default RE: Vtech Kill
I'd say its a pretty good kill considering it's a 4-speed and all. And considering you didn't get the best launch, those 3 cars could easily turn into a larger number with a better one.
Old Sep 20, 2007 | 07:32 PM
  #22
fast65's Avatar
fast65
Thanks, guys. You're right, my car wasn't built for high speeds and unless I drop in a 5 or 6-speed, it never will be. I'm still pretty pleased that I beat him, but I wish I would have gotten a better launch so it wouldn't have been that close at the end.
Old Sep 21, 2007 | 07:47 AM
  #23
S8ER01Z's Avatar
S8ER01Z
Unless you can fix the aerodynamics it never will be... I wouldn't feel safe moving an object with that shape at high speeds... Butt pucker x 10000.
Old Sep 21, 2007 | 10:26 AM
  #24
67mustang302's Avatar
67mustang302
With decent suspension they're actually not that bad. The aerodynamics is offset somewhat by them being light and sorta small, the profile ain't too big. But most newer 4 bangers have WAAAAAYYYYY better aerodynamics than a 60's Mustang, enough to make a difference, especially from a roll at highway speeds. As far as the 4 cyl vs v8, as was stated, you're talking about a car that's 30-35 years older, and prolly heavier. Sport bikes have 4 cylinders, some with less than 1 liter of displacement, but they're fast cuz they don't weigh jack. Bigger cars need bigger engines to be as fast as a smaller car.
Good kill, and work on the launch, the back end is light so on the street you gotta be careful launching. Swap some good heads on there and that same race....you'd have 10 cars by the top of 2nd. What are your cam specs? You might not wanna bother changing it if it's already decent(unless you wanna go from flat tappet to roller). 302's don't need big cams to make power if you have good heads and the right setup
As far as gears, stock gearing was 2.79 on most with 1 leg, some where 3.00, 3.25 or even 3.55 but unless it was a k code or a big block it was prolly a 2.79 or 3.00open diff
Old Sep 21, 2007 | 05:22 PM
  #25
fast65's Avatar
fast65
ORIGINAL: S8ER01Z
It really wasn't too bad at 110, but definetly wants to move all over the road. As for performance, what do you have done to your car 67mustang302?
Old Sep 21, 2007 | 05:36 PM
  #26
67mustang302
If you're wandering at 110 then something's not right, worn ball joints, worn steering box(try tightening up the sector shaft, it may be out of the proper backlash range) etc. As far as me, it's a 302 with Scat 5.7" rods(still stock stroke length, but shorter compression height pistons), Mahle pistons, AFR 165 heads, Crane hyd roller cam, electronic dizzy/box, Weiand intake, Holley 570cfm carb, Hooker long tubes, pullies and some other junk. Just under 9.5:1 compression. Gonna get a supercharger some day, centrifugal and a blow through carb prolly.
Old Sep 21, 2007 | 07:47 PM
  #27
fast65's Avatar
fast65
Do you think a front end alignment would help?
Old Sep 22, 2007 | 11:12 AM
  #28
WRXtranceformed's Avatar
WRXtranceformed
Old Sep 22, 2007 | 11:19 AM
  #29
superdavid's Avatar
superdavid
ORIGINAL: WRXtranceformed
Haha, thats the funniest thing I've seen in a long time! That 65 woulda done alot better with some decent tires on it...
Old Sep 22, 2007 | 12:32 PM
  #30
fast65's Avatar
fast65
ORIGINAL: superdavid
True, it defintely would have. It'd also help if I could launch worth a damn.
