ls1 vs 2v vs blown 2v
im thinking about it, but who knows im starting my new job soon. been jobless for about 2 months now so some mods are on hold. i have some drag radials but i gotta go pick em up. about 4 hours away.
Is the ls1 spraying in the video's if not the mustang is defenitly having problems because i can hold my own better then that agaist ls1 and im a stock bottomend with heads/cams and plus ima conv.
ORIGINAL: flash20
he has a stroked,heads,cam, custom sheet metal intake, 3.55 gears. his car was built for boost but he isnt running boost yet.on motor he is at about 350rwhp with a mild tune.
and the blown 2v is a auto 03 gt with a novi paxton 2000 blowet putting down 347rwhp it also has 4.10's gears and s nitto drag radials.
and all i have on my ls1 is intake, y pipe and catback and a 50 shot. im on stock16in rims
lets see if i can get these vids up
Hell, codes old setup before the stepped tube headers etc was only making something around 340 to the tire, and something like 355-360 now (dynojet) if I remeber correctly. Simply no chance.
347 is terrible for a blown 2v, even with an auto, unless its just a stock PI car + blower and nothing else done. If he has any sort of exhaust/intake boltons tell him to pull down his pants, pull out his junk, and slap his tuner with it.
ORIGINAL: flash20
i was waiting for sum1 to call bs. ive posted up pics of his motor b4. he has a custom sheet metal intake from logan motorsports.
and yes i was spraying in the runs
NowFor the 34Xrwhp i could believe that because i got a stock bottomend(stock intake)with 310rwhp and if he has a stroker it could be reached because (code) didnt have a stroker just bored .20 over and he made 348rwhp i believe.
ORIGINAL: flash20
Your response is he has a cool intake? You must not know that the intake manifolds are FAR FROM the limiting factor on 4.6 2v engine.
P.S. do you really spray a 25 shot? For real? Seriously? No kidding? 25?
ORIGINAL: ZW99GT
That's awesome and all, but he's NOT making 350rwhp on a LOW COMPRESSION ENGINE! My car is fully built just like this guys car is. 11:1 C/R, 302ci, Stage 3 heads, Comp Cams, Ported aftermarket intake, Full exhaust, Full Bolton, etc. I put down 328rwhp. And 3.55 gears and IRS? (guy from the miller high life commercial) He must be crazy.............
ORIGINAL: flash20
i personally don't know exactly what the 2v makes to the wheels
but, his fuel rails are maxed out and he needs new ones/injectors, thats why every time he shifts, it sounds like he can't get it into gear. thats actually the fuel delivery problem
the car is "built" but is at the lowest of it's performance
because, like we said its running at low compression and is waiting for the nitrous/boost.. once it get some sort of juice or f/i then the car will be "done"
none of the races were BS, i was filmog in the camaro...that was CGI in mexico
