Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
60ft times
Old Oct 22, 2007 | 06:26 PM
04StangSC's Avatar
04StangSC
Default 60ft times
What is the best way to improve my 60ft times? I ran 110 in the 1/4 mile this weekend and only ran a 13.3. My buddies told me at 110 i should be in the 12's. Is that true?
Old Oct 22, 2007 | 06:29 PM
willyd465's Avatar
willyd465
Default RE: 60ft times
yes with that trap you should be in the 12's. best way to improve your short time is by experiance. and prolly a good set of dr's would help
Old Oct 22, 2007 | 06:33 PM
04StangSC's Avatar
04StangSC
I plan on ordering a pair of 315 DR this winter and some subframe connectors...should that improve it quite a bit. will the subframe connectors help with wheel hop?
Old Oct 22, 2007 | 06:42 PM
67mustang302's Avatar
67mustang302
If you have wheel hop you need better suspension. Subframes are good for 2 things, 1st they keep you from permenenty twisting the chassis(if you have enough power to do so), or possibly breaking stuff, cracking paint etc, 2nd they keep the body straighter during launch(metal likes to bend) and give you better power transfer. Why use energy to twist the car when you can use it to go down the track
Old Oct 22, 2007 | 06:46 PM
04StangSC's Avatar
04StangSC
I have tokico drag struts and eibach sportlines. My struts are adjustable, do you think adjusting them would help much?
Old Oct 22, 2007 | 06:48 PM
willyd465's Avatar
willyd465
get some control arms with those dr's and you should be able to cut some decent 60'
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Upper and lower control arms and set of good drag radials will be the best ticket to better 60's.
Old Oct 22, 2007 | 06:51 PM
02StangGuy's Avatar
02StangGuy
like willyd said, upper and lower controle arms with some drag radials will get u a nice 60ft. get some bfgs of MT drag radials and youll b happy
Old Oct 22, 2007 | 07:22 PM
04StangSC's Avatar
04StangSC
What is the best brand of control arms? I was looking at the steeda upper and lower's but i want to know what you guys think.
Old Oct 22, 2007 | 07:34 PM
moosestang's Avatar
moosestang
What were your 60 ft times and what gears do you have?
