Zero Confidence
ORIGINAL: Riptide
What happens? Does it just shut the engine off entirely when you hit the limiter?
How hard is a 4K dump on the clutch? I'm a little paranoid about trying it.
I think a 4k dump of the clutch is going to be harder on your tires than the clutch. Just try it and find out. Nothing is going to break. Maybe you should start at 2k and work your way up
If you haven't done it in a car with this much power,you might want to try a big deserted parking lot. If your wheels aren't exactly straight the *** end will drift onyou. You might also experience wheel hop which will feel like you are tearing your car apart.....or so I hear. I'm lucky and haven't had it, but, others say it really sucks. It won't take long and you will absolutely love dropping the hammer on these cars.
ORIGINAL: okbfd
ORIGINAL: Riptide
So if the wheels start hopping on me I should either let off the gas or give it more to get the car to come out of that right?
You'll get the hang of it with some seat time..
You'll know if you get wheel hop, it can get particularly violent sometimes. Just practice launching, and with the traction control OFF. For street tires, pick an rpm and launch so that you're slipping the clutch and giving it gas to keep the rpm up where there's good torque, and continue slipping as you accelerate as hard as you can without spinning(a little bit of spinning is ok, you don't want to just spin and sorta go nowhere though). Practice at a lower rpm and work your way up.
