Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
the ultimate sleeper
Old Apr 30, 2008 | 12:30 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default the ultimate sleeper
seeing the owned by a sleeper thread it got me to thinking about a thread of the same type some time ago.
what's your idea of the perfect sleeper?
Sn95
528 Ford Specifications[ul][*]Bore: 4.42"[*]Stroke: 4.30"[*]Rotating Assy: SCAT cast crankshaft, H-beam rods, 36cc "D" shape dish Diamond pistons, King bearings, balanced[*]Heads: Blue Thunder 74cc, ported, +.100" Ford Racing valves, 3-angle valve job, 10* locks & retainers, 1.625" dia. springs, 230 lbs seat[*]Compression ratio: 9.8:1[*]Rockers: Miller 7075-T7 aircraft aluminum, 1.7 ratio[*]Camshaft: Billet steel roller, custom ground for this engine combo. Lobe = 0.4550" / .4170", LSA = 109* Dur@.050" = .266 / .278, Lift at valve = .757" / .709"[*]Roller Lifters: Morel[*]Block: D0VE-A with Boss 429 bulkheads, thermocleaned and mag checked, HFD Stage 1 oiling mods[*]Bearing clearances: mains = .0035"; rods = .0030"[*]Timing Chain: Ford Racing double-roller with billet gears and 9-position keyway[*]Carburetor: Holley 4500 Series Dominator, 1150 cfm[*]Distributor: MSD breakerless[*]Oil Pump: High Flow Dynamics Stage 1 prepped Melling M84DHV[*]Oil Pan: Armando's 10-qt jet boat pan and pickup[*]Intake: Edelbrock Victor 460 with Dominator carb flange, ported to Blue Thunder intake port size
737HP @ 6300 rpm and 672 lbs-ft of torque @ 4600 rpm, and 95% of peak torque was sustained all the way up to 5900 rpm.
*****this build is from 460ford
[/ul]
Old Apr 30, 2008 | 01:11 PM
DS002's Avatar
DS002
Default RE: the ultimate sleeper
I dont think of any mustang as a sleeper, mustangs are performance cars. Sleepers are cars that perform that arent supposed to or arent made to.
This is a sleeper...
http://www.youtube.com/watch?v=lGNn9lcduyk
Old Apr 30, 2008 | 02:10 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: USMCrebel
Sn95
*****this build is from 460ford [/ul]
How is that a sleeper? The cam would be a dead give away. A sleeper is a car that either appears stock and slow or is not supposed to be a fast car in the first place.
There was a mid 80's Caddy around here that used to be a big street racer, the car looked pretty much stock but ran low 11's/high 10's. That's a sleeper.
Old Apr 30, 2008 | 02:25 PM
USMCrebel's Avatar
USMCrebel
it's a sleeper b/c i said it is, i could fit it all under an almost stock hood. here everything lopes, so it would just sound normal....on my way to school yesterday there was a z28 lopeing HARD as hell, but you couldnt hear it to well over the exhaust of the oldsoble on the other side of me.
Old Apr 30, 2008 | 02:34 PM
USMCrebel's Avatar
USMCrebel
or i guess you could call the one i am actually building right now a sleeper.
stock 302 rebuild kit (mostly), B303 cam, ported/polished Gt40's, Potred polished explorer intake, 60# injectors, A9L computer, built T-5 tranny, twin .60 turbos from turbo coupes. FMIC home made 3" thick. 255 lph fuel pump. etc etc
i dont know if im going to put it into a sn95/ fox body/ or a 240z
Old Apr 30, 2008 | 02:53 PM
Projectquick's Avatar
Projectquick
Well I plan on getting the stock hood after the turbo. The car will be pretty quiet and look stock so most will assume it is stock, soi my car will be a sleeper of sorts. I think the Grand Nationals are factory sleepers, most kids today have no idea what they are until they get ripped apart by an 11 second sixxer.As far as building one, I always wanted to get a ranger and swap in a 302 on the squeeze.
Old Apr 30, 2008 | 03:16 PM
okbfd's Avatar
okbfd
Typhoon/Cyclone..........or my old Dodge Spirit R/T that used to terrorize Stangs/Camaros
Old Apr 30, 2008 | 03:18 PM
USMCrebel's Avatar
USMCrebel
ORIGINAL: okbfd
info on the spirit....what is it
Old Apr 30, 2008 | 03:20 PM
TRBOPWR's Avatar
TRBOPWR
Maybe not the perfect sleeper, but only because they have a cult following and are (in)famous on the roads.
This car ran 9.27 @ ~150 mph.
This ran 12.9 @ 108 on a low boost pass, and notice the curb feelers lol
Old Apr 30, 2008 | 03:39 PM
JD1969's Avatar
JD1969
^^^Now that's a sleeper
