Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
burn out's
Old May 1, 2005 | 07:28 PM
white_snake's Avatar
white_snake
Default burn out's
quick question.
when i go to the track and am about to race, should i do a burn out, seeing that i dont have posi, and only one tire spins. does it help?
i know i only have a V6 but i can still spin the "tire" if i punch it off the line.
thanks
Old May 1, 2005 | 07:31 PM
UT04GT's Avatar
UT04GT
Default RE: burn out's
unless you're on slicks or drag radials, doing a burnout won't do any good. At the track there's usually idiots who use the water box and don't know how to clear off the water and end up dragging water up to the line, so sometimes it's necessary to spin the tires clean. just do a quick rolling spin and that should do the trick
Old May 1, 2005 | 07:51 PM
JonBeast's Avatar
JonBeast
Moderator
Just drive around the water box
Old May 1, 2005 | 08:19 PM
white_snake
ya at the track i go to you cant really drive around it....you have to go through it a bit......so thats a negative on the burn out then, unless tires are wet cool thanks
Old May 1, 2005 | 09:08 PM
dan's Avatar
dan
not sure with your rear end, but with stock tires you should just spin them around a few times just to simply clean them off, no smoke or anything like that
Old May 1, 2005 | 10:55 PM
Dan04COBRA's Avatar
Dan04COBRA
Don't bother smoking your tires. You'll just make them greasy, wrong compound to be smoking.
Just do a one wheel peel for 2-3 seconds to clean it off and you're ready to go.
Old May 1, 2005 | 11:39 PM
white_snake
ok thanks guys. ill be ready next weekend when i go to the strip...[sm=gears.gif]
Nurdyguy
Jan 20, 2025 04:38 PM
CS2007
Jun 25, 2019 09:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
jhawkr
Oct 30, 2015 01:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
