Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
I hate nitrous
Old May 9, 2005 | 07:51 PM
dan's Avatar
dan
Default RE: I hate nitrous
If you have a WOT switch, would it be necessary to get a 1st gear lockout, so you dont completly kill your traction
Old May 9, 2005 | 10:01 PM
Sidewayz6.0's Avatar
Sidewayz6.0
How big of shot are you running?
If you're running a 125 or under...Why are you using a wet kit?
Old May 10, 2005 | 05:06 AM
sk8erdudex's Avatar
sk8erdudex
100 shot explain please
Old May 10, 2005 | 01:28 PM
iwrxit's Avatar
iwrxit
there is a nitrous master mind that can control the amount of juice you get in eacj gear. i dont see what tires you used, but you wont hook on street tires and a 100 shot off the line. i know summit racing sells them.
Old May 12, 2005 | 12:17 AM
C/Note's Avatar
C/Note
I ♥ Acer
i use up a bottle in less than 4 passes with 175 shot.. the bottle is a 10 lb er but the last 4lbs is not a liquid... meaning you will still have pressure but no liquid just gas..does that even make cents....
Old May 12, 2005 | 02:22 AM
sk8erdudex's Avatar
sk8erdudex
The only reason NOS is a liquid in the bottle is because it's under so much pressure. But your right its only gas and you still have pressure but not enough to produce a 175 shot lol
Old May 12, 2005 | 09:55 AM
TommyV8's Avatar
TommyV8
ORIGINAL: sidewayz4.6
ORIGINAL: sk8erdudex
I believe he means that if you're spraying a small shot, you don't need to supply additional fuel, the stock fuel system should be able to handle it. Then this wouldn't have happened.
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
Ipaman
Sep 22, 2015 07:01 AM
ccdguy
Sep 19, 2015 05:20 PM
BrantleyS550
Sep 14, 2015 04:18 PM
jaiidutch
Sep 14, 2015 10:29 AM
