First decent kill with the blower
I know a C6 Z06 would put a nice hurting on me. Suspension mods are: BMR adj LCAs, steeda ultralite lowering springs, steeda rear sway, Spohn adj Panhard rod, BMR panhard rod brace, Tokico D-specs, and camber bolts. Other mods include: Che K-member brace with torque limitors, sypdershaft 1-piece aluminum driveshaft, spec 2+ clutch, competition steel flywheel, and MGW sts. I think thats everything. The stock rims and stock exhaust make it such a sleeper!
From: Where gunshots are more common than birds chirping
I didn't see a set of LCA relocation brackets in there and I'm sure that would help you plant the tires harder especially with your car lowered. Sounds pretty mean though.
yeah, I skipped out on the LCA relo brackets due to cost when I overhauled the suspension, since I had done everything at once. After I get the clutch/slave cylinder issue figured out, I'll spring for some LCA relo brackets and aftermarket Upper control arms.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dragonus18
Sep 9, 2015 01:21 AM
