Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
raced a G37!
Old Feb 5, 2009 | 12:59 PM
  #21
83gtragtop's Avatar
83gtragtop
Originally Posted by scg87
83- Pre HR, non-revup Z's usually make right around the 225whp mark. I'm surprised you 'beat up on' the guy's Z, but it is what it is. Was his car auto, or did he suck at driving??
I was being sarcastic when I said I "beat up on" the Z. Which is why I wrote "(edged out)" right after that. The Z was usually at my bumper to about 90 when we would shut down.
The Z was a stick and I don't believe he sucked at driving because the results of our 10mph punches were pretty consistent. Note that my car weights a tad under 3100lbs, so I have a 250-300lb weight advantage. Combine that with 3.73's and a strong low end for those low speed punches, I believe the results make sense.
If you're questioning my '83 making 210rwhp, thats fair. I have not had it dynoed since recent mods. The car made 190rwhp with just a dual exhaust conversion. Since then I've added a few mods; Edelbrock Intake Manifold(big SOP difference), UDP's and 1-5/8 headers(replaced the crimped stock '87+ I was running). I'm guessing I'm close to that mark.
As for the G37, I wasn't aware they'd gone that quick stock, but I'm not calling you a liar. I haven't been over on their boards for a while. Anyways, the HR Z's have gotten into the 13.1x's w/ a good number seeing 13.3-40's. They've got about a 350lb weight advantage, though. Gearing may factor in as well, not sure what G37's have out back.
I've seen a 13.3 slip posted on G37 forums. I also saw a slip of a guy running 12.9 stock with D/R's.
Whats the difference in rwhp?
Old Feb 5, 2009 | 02:20 PM
  #22
Projectquick's Avatar
Projectquick
210 sounds about right for your car. I've had some pretty good luck against the older 350Zs and G35s with my car, but I guess the cam really helps on the top end.
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
Sep 29, 2015 03:23 PM
mungodrums
Sep 28, 2015 10:54 PM
