One run Capability?
Oh really? I did not know it already went that good on the 60, I take back what I said then. Probably a low 1.4 then. It really shocks me that it went that good of a 60 with kind of suspension on a DR.
So if I went to a Bias Ply slick, could I get into the 1.3' s?
I'll probably raise height, and soften the rebound, which should lower the spring rate and soften the suspension.
Either way, I think the car is capable of a low 10 and a 140mph trap if I race at close to sea level.
I was planning on driving to one of those nice tracks with a DA at or below sea level.
IMHO with a 3.55 gear and the IRS a 1.3 is not attainable with your set up and would be hard even if you had a solid rear and 4.30s. a mid 10 sec pass is certainly possible for your set up IMO if you can pull a 1.5 60' which is realistic
Good god man, being at sea level will probably make the most difference along with a good DR. What was your elevation before hand when you ran that 11.07? I do agree with the masses and say you may need more than one run, I'd say 5 should do the trick. I would like you to prove us all wrong and do it on one pass though.
