Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
One run Capability?
Old Mar 6, 2009 | 05:39 PM
  #21
Stkjock's Avatar
Stkjock
Retired Mod
Originally Posted by bolivianpimp
2000AZ5.0GT - Has a built engine and s/c or turbo? How much lbs of boost?
guess it was too much trouble to click on his garage link??
built motor,Vortech @ 15.7lbs IIRC
Old Mar 6, 2009 | 09:48 PM
  #22
Blownsvt's Avatar
Blownsvt
140 is optomistic. i have yet to trap 140 but have not been to run at the track much yet and the one time i did i was bogging out pretty bad. a car like mine full weight should trap around 140 or so. I also have never seen an irs car cut a sub 1.6 60 ft time.
Old Mar 6, 2009 | 10:20 PM
  #23
2000AZ5.0GT's Avatar
2000AZ5.0GT
I'm running less weight than you though, Raceweight is 3450 (with me in it).
I've actually just learned that me loosing about 1PSI of boost above 6900RPM is because of valve float, so more boost is on the way. I'm still a good 2 pulley sizes away from the max that I can run with the T-trim, so there's not even any reason that I should look at upgrading, everything considered.
I was kind of weary about changing pulleys, but to do it just for the race, and then pulley back up, I think I'll be fine. I'll also be adding an FMIC in the next month, so I think I'll be able to reliably maintain ~700rwhp with this combo, as it sits. I'm running a sumped setup now as well anyway, so I think I'll be fine.
Old Mar 6, 2009 | 10:23 PM
  #24
2000AZ5.0GT
Fortified Chassis, Built Motor, Built Transmission, Braced to hell IRS, Vortech @ ~16lbs (depends on elevation)
thats the simplist way I can put it.
Old Mar 6, 2009 | 11:10 PM
  #25
Blownsvt's Avatar
Blownsvt
well good luck. how much power are you actually making now?
Old Mar 7, 2009 | 12:36 AM
  #26
2000AZ5.0GT
I have not a clue. as I was telling a little "know-it-all" in the 4.6 section, I havn't been on a chassis/engine dyno in over a year and a half now, I do all my own tuning myself.
Back when I WAS on a chassis dyno, the one in tucson, at 3300' Above Sea Level had me putting down 582rwhp through the 4R700W SAE UN-corrected.
If I were just BSing, I'd guestimate that I'd probably be putting down 610 at the wheels where I'm at, I think that's probably fair now that I'm going through a 6spd.
Just on the theory side of things, I'd have to think adding an FMIC, keeping the meth, and going with more boost, I'd probably see ~700 at the wheels, + or - 20hp
But that's all speculative. I never really cared for numbers, I was always more interested in the car performing the way I wanted it to, and as long as it did that, everything else was just icing on the cake.
Old Mar 9, 2009 | 09:37 AM
  #27
AmericanSpeed's Avatar
AmericanSpeed
I'm looking foward to seeing what you will trap. So what date is the trip planned?
Old Mar 9, 2009 | 09:54 AM
  #28
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
i've seen COBRA's and supras and vettes cut 1.4's and the supra cut a 1.27 (1800rwhp though lol)
but the vette and the cobra cut 1.4's all day
Old Mar 9, 2009 | 12:48 PM
  #29
ZW99GT's Avatar
ZW99GT
1.3X 60ft is a MONUMENTAL goal to set for yourself. You will most certainly need a 28in SLICK to even being to think about hooking HARD. A radial isnt gonna be much better as far as planting 600rwhp in 1st gear from like a 4500rpm launch.
If I were you and cut a 1.49 I'd be thrilled.
Old Mar 9, 2009 | 01:58 PM
  #30
Ryan86272's Avatar
Ryan86272
Id say the biggest thing is your Launch..... My Friend had a 710whp 03 Cobra Solid Rear... he ran 10.2's at 142mph.. (Dont know his 60ft). It will be interesting to see what you run! Good Luck
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
uedlose
Sep 10, 2015 03:30 PM
Sep 8, 2015 11:50 AM
