Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
WRX STi....?
Old Jun 30, 2005 | 05:29 PM
  #21
iwrxit's Avatar
iwrxit
Default RE: WRX STi....?
ORIGINAL: matthockey32
the dealership says up to 20 lbs on stock internals. with an FMI and full exhaust you have 325 awhp and 35ft-lbs torque
thats with the stock turbo. a couple of my sti buddys run FP green turbos on 24-26psi daily driven. stock internals. they put down 400 to the wheels. im a puss and use the stock turbo to 19 psi. i only put down around 300 or so...
Old Jul 1, 2005 | 12:06 AM
  #22
matthockey32's Avatar
matthockey32
I ♥ Acer
ORIGINAL: iwrxit
less than a stock EVO. i saw a mitsubishi STi evolution VIII today. how rice is that. those things are junk. the guy tries to take off from a light and lays rubber with the front tires and the rears are stopped, like a FWD evo. JUNK
Old Jul 1, 2005 | 12:10 AM
  #23
Guest
Guest
Posts: n/a
ORIGINAL: iwrxit
So he pulled the ebrake to do a FWD burnout and ... the car is junk? and putting 300 hp to the ground is more than the EVO 8 makes to the crank...
Old Jul 1, 2005 | 12:33 AM
  #24
matthockey32
I ♥ Acer
ORIGINAL: 2000Si
ORIGINAL: iwrxit
i meant boost. evos run 19 lbs of boost. and he didn't pull the e-brake, he dumped the clutch. evos are junk. seen too many of them break after getting slightly modded. by slightly i mean hard pipe kit, exhaust, and ECU
Old Jul 1, 2005 | 12:44 AM
  #25
ldstang50's Avatar
ldstang50
the 03/04 evo's made 271 hp and 276 torque. the 05's made 276hp and 282 torque. the 05s have a 10.5 hotside a different compressor opening, larger waste gate flapper and a slightly more aggresive tune. the evo's come from the factory rich as hell, falling to a 9.7 (or even lower) a/f ratio. the 03/04s peaked at 19lbs and fell to 16, while the 05s peaked at 20.5 and fell to 17.
My buddy has an 05 MR (the only year the MRs were made) and with just an afc, mbc and cat back he ran 12.2@111 bouncing off the rev limiter in 4th. Had he had a regular evo with a 5spd i would not be surprised to see him break 11s on $500 worth of mods.
for more proof of how nasty the evo's can get have a look at www.srvidz.com and watch the evo there spank KB cobras, NOS and cammed ls1s and various of other cars from 60mph roll races.
The STi makes more hp stock, but with just an afc you can get more hp out of an evo than you would out of an sti with an afc
And for those of you talkign about torque. I made 375wtq at 3300 rpm and it fell to about 310wtq at 7500 rpm. I currently have for mods: cams, cam gears, hg, mbc, exhuast, intake, tune and fuel pump
Old Jul 1, 2005 | 12:48 AM
  #26
ldstang50's Avatar
ldstang50
my evo is holding up just fine.
and to do a fwd burnout with an awd car, all you need to do is lower the front tire pressure, my buddy did it two weeks ago in his 1g eclipse
Old Jul 1, 2005 | 05:42 AM
  #27
Phillyblunt474's Avatar
Phillyblunt474
Hey i kinda like the looks of the STi, and supposdly that large wing is functional at 100mph
But they are no joke, dont wanna get into a fude with them you will get a hurtin
Old Jul 1, 2005 | 10:01 AM
  #28
ldstang50's Avatar
ldstang50
the evo's wing is functional at 85mph, but with teh mr vortex generators its functional at 73mph. the sti wing is functional, but at what speed i do not know
Old Jul 1, 2005 | 02:45 PM
  #29
iwrxit's Avatar
iwrxit
the STi wing is around 100mph. some of the guys say the car get shaky around there w/o the wing. i wouldnt know, i took my wrx wing off, i dont need high speed downforce.
the thing i dodnt like about the evo was 271hp w/ 19 psi and a bigger turbo than the STi. the displacement makes all the difference. i know aboutt the shootouts, and evos winning...but thats because the 4g63 is older and proven. evos do spin the fronts. thats how i beat the ones i have raced.
and yes, at the moment, and for a while, the 4g63 will have TONS more parts available for cheaper than the EJ257.
power potential=evo
my preference=STi
real life=evo by far, because subaru is really a bunch of pussies. no joke. the corporation is hella lame.
Casper98GT
Oct 29, 2004 02:43 PM
Redline03GT
Aug 6, 2004 12:09 PM
95Stealth302
Jul 2, 2004 12:13 PM
