Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
60ft
Old Jul 13, 2009 | 03:19 PM
VistaGT's Avatar
VistaGT
Default 60ft
How does the 60ft affect the 1/4 as far as ET?
Right now I've only done a few passes in my car and don't have much experience.
With 4.10 gears and street tires, traction is limited.
So far my best is a 13.5@104.5 with a 2.0X 60ft(prob high 2.0)
How does bringing the 60ft bring down the ET? I definitely spin for more than 60 feet-all of first and chirp 2nd.
Ex: what would a tenth off the 60ft bring off the ET? Let's say I cut a 1.8 60. WHat could I expect the ET to be?
Thanks!
Old Jul 13, 2009 | 03:23 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
There is a generally accepted consensus that a tenth *.1* off of your 60' will result in about a two tenth *.2* drop on your ET.
However, a lot more goes into effecting the outcome than that.
Having said that though, your trap is quite healthy and you're therefor leaving most of your time at the start. If your trap was significantly lower I'd say you had tons of time on the table.
If you had some sticky tires *like a drag radial* or were able to just drive the hell out of your car to a 1.8 60' I'd say you've got bottom 13's and maybe high 12's in the car as it sits.
I went from 14.5 with a 2.2 60' to a 13.6 with a 1.8 60', but there was a lot more than my trap affecting my ET. I was new to the car, couldn't shift hard or at the correct rpms consistently.
Good luck. Even a 13.5 isn't bad for street tires.
Old Jul 13, 2009 | 03:32 PM
Projectquick's Avatar
Projectquick
Like Mach said it's generally accpeted that .1 off your 60' timeshould equal .2 off your ET. For example last year the best I could get out of my car on street tires was a 2.2 60' and I pulled consistant 14.2-14.3s, I borrowed a buddy's DRs and made 2 passes and I was cutting 2.0 60's, and on the one run I didn't completly **** up I pulled a 14.0, but that was with a soft launch and an early 2-3 shift.
Old Jul 13, 2009 | 03:51 PM
VistaGT's Avatar
VistaGT
Thanks!
and I'm more hoping for the high 12s ;-) .........others with my mods get it, and over 300wheel doesnt hurt either.
I guess practice, practice, practice-----though this may not be possible on street tires with the gears
Old Jul 13, 2009 | 03:54 PM
mrtstang's Avatar
mrtstang
I recently went from sumitomo htrz street tires to some nitto dr's. With the same mods on both occasions, i went from a 13.6 with a 2.1 60ft. to a 13.3 with a 1.9 60ft. on my n/a runs. It was my first time on dr's. With practice i know i could cut a 1.8, and pull very low 13's.
Old Jul 13, 2009 | 03:56 PM
Riptide's Avatar
Riptide
You're not doing bad. I can't get under a 2.3 60' with the stock tires on my car. Back when I had the 3.55 gears and just the intake/tune.
Old Jul 14, 2009 | 01:28 AM
Intervention's Avatar
Intervention
Just like everyone has been saying, .1 =.2
Find yourself a pair of 275/40/17 Mickey Thompson ET Street Radials. Do a small burnout (3-5 seconds) and let her rip.
As a side note:
I swear the dyno I go to reads stupid low. I have the "same" whp as the OP but trap nearly 5mph more, its weird.
This is my best pass on streets
60 Foot Time: 2.063 330 Foot Time: 5.580 1/8 Mile Time: 8.453 1/8 Mile MPH: 86.03 1000 Foot Time: 10.912 1/4 Mile Time: 12.985 1/4 Mile MPH: 108.93
Old Jul 14, 2009 | 02:59 AM
83gtragtop's Avatar
83gtragtop
D/R's and practice will get you those 12 sec runs.
Old Jul 14, 2009 | 03:02 AM
83gtragtop's Avatar
83gtragtop
As a side note:
You pick up alot of MPH on the big end. I would think you have between 320-325 with mods listed.
Like they say, you don't like your dyno numbers just find another dyno.
Old Jul 14, 2009 | 03:49 PM
VistaGT's Avatar
VistaGT
So I'm guessing it's no go on nitto 555 street tires then??
Also how does the stock drivetrain hold up to launching on DR's??
If I go to the track every once and a while and launch it,how will it affect my driveshaft, posi, trans etc...?? Am I gonna break the DS in two?
Thanks!
