Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Popped the cherry..
Old May 28, 2011 | 10:58 AM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Originally Posted by Pete_Rockett
That's right. My logic was that if I couldn't let it shift hard on the 93 I was losing time, so if I put the milder tune on I could run harder. It seems to have worked, but I know that is a band-aid. I have to learn to drive the car to its full potential with any tune; at the same time, that might require better rear tires.
I gotta get the power to the ground!
You're 90% right here.
Erase "might" with, "will"
Good to have fun your first time out, I know I didn't.
Old May 28, 2011 | 11:23 AM
darkmach1's Avatar
darkmach1
Need some M/Ts.
Old May 28, 2011 | 12:52 PM
Mishri's Avatar
Mishri
Mish-ogynist
I'm going to need wider tires asap for driving around on, i felt the rear kicking out pretty bad when i got to the top of 1st gear had to back off and haven't had a chance to do another 0-80ish run. and that was with traction control on. My M&Hs should be good for now at the track. I really dont know why they didn't put wider tires on these cars, the 235s are completely inadequate, even when stock. they were okay on the 3valve hainvg 100 less hp not anymore.
Old May 28, 2011 | 02:07 PM
Stone629's Avatar
Stone629
The thing is, I have made WOT runs from a standing start on the "street" (country road, mile of straight, no one in sight), with the tune on, and T/C OFF, all the way to 100 mph. I expected a little spin on all the shifts, but going sideways was so far out in left field I just couldn't imagine it would happen. One of the officials told me to put T/C back on, and I figured OK for a first timer while I sort of figured things out.
It really was a learning experience and I think I can get in the 12's next time.
I know exactly what your talking about. I have experienced the same thing, spin less on public roads, spin worse at the track. I really think there is a fine line between having a well prepped track and having a ice skating ring for a track, depending on what is mostly running that day (crotch rockets and street tires ruin track prep), temps, moisture on the track, amount of VHT, etc. Did you by any chance drive through the water box on that first run? May have just been a lot of water tracked ahead of the box from the person before you too. Either way, I think you did just fine for your first time out. You'll be surprised how much you improve after each trip out.
One other I've noticed is that if I run immediately after they spray the track, I spin like none other (street tires). Even with my trailblazer, I can't go more than 1/4 throttle if I go behind that crap. Once a few cars with slicks go ahead, then it'll start hooking. Never really pinpointed that one.
cr620
Oct 3, 2022 10:18 PM
MacSerio
Sep 27, 2015 01:05 PM
humpbackshooter
Sep 24, 2015 10:07 AM
gagemcc
Sep 22, 2015 09:43 AM
Sminemann
Sep 17, 2015 09:24 AM
