Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
which tires?
Old Sep 8, 2005 | 04:06 PM
eZ's Avatar
eZ
Default which tires?
hey fellas i dont know come-here from sick-em about drag racing but im bout done with my 64.5 muffstang. im runnin about 340-370 horse out of my 5.0. 9' rear with 4.11 and an Aod tranny. yea i know i should have gone with the T-5 but im an idiot. Im also going to spray it a bit. looking to buy tires that will be good on the strip but have a decent street life. car will not be driven much. the rims are 17x8.
thnx for the help and see you on the 1320!!!!!!!!
Old Sep 8, 2005 | 04:28 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: which tires?
Micky Thompson ET Street Radial. Comes in a 17 inch and is the best drag radial on the market. Wear on the street is not that good but you should be able to 3-5000 miles depending how you treat them.
Old Sep 8, 2005 | 04:34 PM
eZ's Avatar
eZ
what kind of price range are the dr's? should i buy normal tires for my nice rims and buy smaller rear rims for better tires?
i would like to get better then 3-5000 out of them
Old Sep 8, 2005 | 05:23 PM
Demon 340's Avatar
Demon 340
Administrator
while i am by no means arguing with JD, I prefer hoosier QTPs...
Old Sep 8, 2005 | 05:45 PM
JD1969's Avatar
JD1969
ORIGINAL: Ride Of The Month
Thats a good tire as well, it's just not a radial. not sure if it is offered in a 17" either
ORIGINAL: eZ
You will hook better on a tire that has a taller sidewall, so getting a second set of smaller diameter rear wheels is a good way to go plus then you won't be putting as many street miles on them. As far as wear goes, that the trade off for having a tire that hooks. The BFG Drag Radial lasts longer than the M/T and the Nitto lasts the longest (but hooks the worst). Price range is about $130 or so per tire.
Old Sep 8, 2005 | 09:03 PM
Demon 340's Avatar
Demon 340
Administrator
whoops..my bad...none of the QTs are offered in 17s...but i would look into a 15" rim...just my opinion though...
Old Sep 9, 2005 | 01:40 AM
eZ's Avatar
eZ
thnx for the help ill get some 15's for the rear i can actually get the ones that match my 17's...that will look comedy with 15's in the back and 17's in the front
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
