Suspension Ask all of your general suspension questions here!
Rear axle shift when lowering
Old Jun 26, 2011 | 09:21 PM
  #21
Norm Peterson's Avatar
Norm Peterson
With a PHB there are at least two major asymmetric effects.
The geometric roll center height rises when turning one way and drops when you turn the other way. The first is a "loosening" effect, the second tightens. Differences in the roll angles for L vs R turns may or may not be noticeable.
Rear axle roll steer varies as well, increasing when turning one way, lessening when you turn the other way. Most times, this effect acts in opposition to the geo-RC vertical migration effect.
That's generally what happens. The overall effect depends on the details (and the devil inside).
It is possible to use PHB asymmetries to offset the asymmetric effect of driveshaft torque trying to load the LR and unload the RR. I think the intent here is to balance the handling behavior and "feel" when adding throttle on corner exit. Consistent behavior = predictable = fast.
Norm
Nov 10, 2015 11:39 AM
musnicki
Sep 23, 2015 07:11 AM
Dragonus18
Sep 9, 2015 01:21 AM
Sep 3, 2015 07:14 PM
cbird1177711
Sep 2, 2015 08:51 PM
