Suspension Ask all of your general suspension questions here!
Rear axle shift when lowering
Old Jun 12, 2011 | 01:03 AM
HOTRODD77's Avatar
HOTRODD77
Default Rear axle shift when lowering
So I recently put a new set of staggered wheels on, and even at stock height I can see that the axle is not centered. I do plan on lowering it soon and my question is this: When you lower the car, does the axle always shift to the same side on every car? I'm asking, because if that is the case, I wonder if it will actually shift itself more center and I might not need a panhard bar.Any help would be appreciated. Thanks!
Old Jun 12, 2011 | 02:25 AM
socalwrench's Avatar
socalwrench
Yes, the axle will move whenever the ride height is changed. The axle travels in an arch with the 3 link and panhard design. The mounting point for the panhard bar is on the right for the S197 chassis; not every car is the same.
My axle wasn't centered perfectly either, and now that's lowered it still slightly off center. An adjustable panhard bar should be used, but you won't know until the car is lowered and settled on that suspension; that's where to on-car adjustable one comes in.
Best of luck. UMI makes great stuff.
Old Jun 12, 2011 | 08:12 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
^ I agree
If you go with UMI, or any other brand, be sure to get a PHB that has the adjustable nut at the very end of the bar and as far away from the center as possible. The bar can get quite a load, in terms of compression on a RH corner and the adjustament nut is the weakest link. The bar will bow a bit under heavy loads, so best to keep that nut right at the end.
Jazzer and $.02
EDIT: I realize the nut toward the middle is easier to adjust, but you only need to do it once
Jazzer-approved design
Jazzes non-approved design
Last edited by Jazzer The Cat; Jun 15, 2011 at 06:37 AM. Reason: Updating post with images corrected info
Old Jun 14, 2011 | 07:18 AM
Norm Peterson's Avatar
Norm Peterson
Since you didn't mention which way the axle is off-centered in, it's kind of difficult to tell you for sure what is going to happen.
With the S197, most times lowering will push the axle toward the driver side. So if it's already "off" toward the passenger side the lowering will tend to offset this (and can end up "overdoing" it). If you're already "off" toward the driver side you could expect the off-centeredness to get worse. Depending on how fussy you are (or need to be for big tire clearance reasons), there can be more situations that might require correction than not.
But since the PHB can be done completely separately from the lowering, all you really have to do is get the lowering done and see what needs to be done at that time.
I'm in full agreement with Jazzer with respect to the adjuster location and expected use. Unless you're going to be swapping springs like most folks change underwear, PHB adjustment is not something that you'll have to be constantly fiddling with. Spend a little longer getting the structurally better PHB that's less convenient to adjust, adjusted the first time. At most, adjust it once more if the springs take an intial set, and you'll be done with it.
Norm
Old Jun 21, 2011 | 04:31 PM
cydonian man's Avatar
cydonian man
yeah, dont get the Ford Racing PHB. it has the adjusting nut in a non-desirable position. if they made one with the nut on the end i would get it. but like they said, there are different aftermarket brands to choose from.
Old Jun 23, 2011 | 12:27 AM
HOTRODD77's Avatar
HOTRODD77
Thanks a lot for the info guys!
Originally Posted by socalwrench
Yes, the axle will move whenever the ride height is changed. Best of luck. UMI makes great stuff.
YEah, just wasnt sure if it tended to go to the same side every time. I'll check out the umi bars! Thanks!
Originally Posted by Jazzer The Cat
^ I agree
Very good to know, thanks for that! So can you provide some info on the difference in these two:
http://www.umiperformance.com/catalo...roducts_id=308
http://www.umiperformance.com/catalo...roducts_id=248
Is the grease/lube they offer something to get, or is there better elsewhere?
Norm
This is what I was thinking, and it is off center toward the drivers side now, so looks like it's going to just get worse. No huge tires, just 285's out back, and when they went on I could see a little more tire on the drivers side.
Old Jun 23, 2011 | 07:30 AM
Jazzer The Cat
Retired Moderator
Of the two links for PHB's listed above, my personal preference for higher performance is the the second one. It will generate a bit more NVH, but just like to relieve bind in ALL ways possible on suspension components. In this case, there will be VERY little, but just how I approach this stuff.
If they have a tube of grease that comes with the bar, I'd recommend you get it.
Jazzer
Old Jun 23, 2011 | 09:23 AM
allinon72's Avatar
allinon72
I have the "non-approved design" panhard bar, but mine is a BMR, and the adjustment nut is about twice the size of the UMI.
Old Jun 23, 2011 | 09:43 AM
jlc41's Avatar
jlc41
OP,.... you may want to lookup wattslink also.
Old Jun 24, 2011 | 04:18 AM
ModMe's Avatar
ModMe
I would go this route if I was going to the track and wanted the BEST setup. For the street, these cars handle pretty good with a few minor tweaks (panhard, swaybar, shocks, and bushings). You will also need to look into adjustable lower or upper control arms to correct pinion angle depending on how low you go.
