Suspension Ask all of your general suspension questions here!
Lowering With Wheel Spacers
Old Dec 26, 2017 | 04:41 PM
robbysock's Avatar
robbysock
Default Lowering With Wheel Spacers
I have a 2017 Mustang with 2 inch wheel spacers. I was wondering how low I could go on lowering the car without causing any rubbing or issues?
I really like the widened stance of the wheels spacers but because the wheels come out so much, I'm worried about dropping it.
Any advice or suggestions would be appreciated.
Thank you
Old Dec 28, 2017 | 01:20 PM
Buck Sergeant's Avatar
Buck Sergeant
robbysock, everyone knows I do not favor any spacer, in less absolutely necessary. Besides having to torque, and worry about, two sets of nuts, I have always questioned if the wheel bearings, and studs, are subjected to additional stress. I always recommend, and use, offset rims. In your case you would need a "negative" offset rim to bring the wheel out. If anyone has had a "wheel bearing issue," when using wheel spacers, or "stud issues," please tag it onto your reply.
Old Dec 29, 2017 | 01:04 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Thank you
If you plan on dropping the car at all and keeping your existing wheels and "stance" you'll need to do one of two things, roll the fenders or widen your wheel wells. The third option which is an abomination to the mustang is to give yourself a shizt-ton of negative camber so that the top of the wheel tucks in under the fender.........
Regardless, how much you drop is limited due to the wheel clearance issue.
Old Dec 29, 2017 | 04:21 PM
Buck Sergeant
robbysock, Derf00 hit the nail on the head. You can only lower the car,and clear the fender well, in accordance with your tire diameter and tread width. Anything that gives you a "negative" offset rim, brings the tire outward, usually causing the tire to rub the outer finder. There are a ton of different lowering combinations available through aftermarket vendors. I would call a reputable vendor and explain exactly what you want to accomplish, and how to do it, so you will be proud how your ride sits.
Old Dec 29, 2017 | 04:28 PM
Buck Sergeant
Derf00, did you do any "oval racing"? I started laughing when I saw "roll the fenders." I remember, back in the day, when we always had a baseball bat in the car trailer so we could "roll the fenders" in case we got hit and a tire was rubbing. I really miss those days. Thanks for the memories.
Old Jan 2, 2018 | 04:11 PM
01GT4.6's Avatar
01GT4.6
Thank you
Why 2" spacers? I lowered mine with 1" spacers and IMO it looks perfect. 2" spacers will stick the wheels out past the fender (unless you have some skinny wheels or a crazy offset)
project85
May 30, 2018 09:18 PM
DylanFan
Mar 9, 2011 07:56 PM
tarpymac
May 15, 2004 03:08 PM
whitelightning
Dec 1, 2003 07:24 PM
tbeckman
Nov 30, 2003 11:27 PM
