Ball Joint woes!
I just bought an 88LX with an SVO motor/suspension swap. I found out afterwards that the ball joints are going bad and I can't replace them. What have some of you guys been doing to correct this?
Current mods
Holley Anialator Ignition with a MSD timing retard
LA3/ Big Vam/ 35lb injectors
15lb boost (more to come)
Mustang SVO suspension 5 lug pattern, Disk brake SVO rear diff
17" mustang tri spokes
Trunk mounted battery
Aftermarket shifter
Turbonetics t3/t4, to4e 50 trim, stage II, 50/.63 ar Hybrid
-38x12x4 front mount intercooler
-holley 255hp fuel pump
-bbk afpr
-2.5 exhaust with hooker aerochamber
-t5 trans
-3:45 traclock 7.5 with 11" rear discs
-73mm front calipers w/11" rotors
-84 svo lower control arms, sway bars and coil springs
-Kyb shocks all round
Thanks
Marty
Current mods
Aftermarket shifter
-bbk afpr
-t5 trans
Thanks
Marty
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
