SVT Forums
03/04 Terminator question
Old Jul 25, 2006 | 11:59 AM
PushinTheLimit's Avatar
PushinTheLimit
Default 03/04 Terminator question
What was the supercharger that came stock on these? I thought it was KB but someone said it was Eaton? Or is this the same thing with just a different name? Also, which one performs better? Just curious as to what the differences are.
Old Jul 25, 2006 | 12:31 PM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: 03/04 Terminator question
The Eaton is stock.
It's limitations are around 500RWHP with some porting.
The KB is a lot more effecient of a SC.
Old Jul 26, 2006 | 05:30 PM
beastzilla02's Avatar
beastzilla02
so some cobras have KB and some have Eaton superchargers ??
Old Jul 26, 2006 | 05:41 PM
stanger99's Avatar
stanger99
some also have a whipple or a turbo or whatever other charger they can think of but STOCK terminators came with a eaton m-112 i believe but like dan said a kb is ALOT more effecient than a eaton for one the boost level is greater i believe they run cooler also however it really makes no sense to even look into one unless you plan 500-550 rwhp because anything less than that can be achieved with the stock eaton with some porting, pulley swap etc.
Old Aug 5, 2006 | 04:42 AM
zincsvtcobra's Avatar
zincsvtcobra
03-04 Cobras come stock with an Eaton M-112 S/C. The Kenne Bell and Whipple S/C are aftermarket ones. M-112 comes from the S/C adding about 112 CI to the 281 engine.
Old Aug 11, 2006 | 06:03 PM
CobraBob's Avatar
CobraBob
The Eaton S/C is good for 525-535rwhp without nitrous with a port job. Depends on how much boost you're running. 16-17 lbs. max is recommended but some push 18-19 lbs. If you're looking for more than 520rwhp I'd recommend the Whipple or 2.6 Kenne Bell. The Kenne Bell 2.2 and 2.4 are discontinued.
Dokilar
15
Oct 16, 2015 08:13 PM
Bokeo
Oct 10, 2015 08:28 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
