SVT Forums
5.4L in a 4.6L Bay??
Old Aug 30, 2006 | 12:07 PM
drdarkman's Avatar
drdarkman
Default 5.4L in a 4.6L Bay??
is it possible to remove the factory 03-04 cobra engine and put in it's place a 5.4L superchargerd engine. in a sense it would basically be the Ford GT engine. also being supercharged as well.
Old Aug 30, 2006 | 12:11 PM
SpecterGT260's Avatar
SpecterGT260
Default RE: 5.4L in a 4.6L Bay??
it still wont be the GT engine. there are 3 different 5.4s. I know the 5.4 sohc is direct bolt in for the PI GT bay. i would suspect it would work for your cobra as well. the DOHC from the lightning will probably work too. the GT aluminum block is designed to fit in the back of the GT, so i doubt it will mount easily into any mustang bay. go with the lightning setup, and you will do just fine. u may need a different hood though if u go with a roots or TS SC
Old Aug 30, 2006 | 12:23 PM
drdarkman's Avatar
drdarkman
Thats a good point on the GT engine. Does the lightning engine have a forged bottom end also like the cobra's does? if so, is it just as strong, or is it stronger?? and i would also be concerned about the header setup as well. seeing that they were two difference engines. would i have to make custom headers, or would the cobra headers work just fine?
Old Aug 30, 2006 | 12:26 PM
SpecterGT260
i think it is forged, but i only think that because ive seen people boost and spray the crap out of them. no guarantees.
as for headers, u would HAVE to get 5.4L headers, but maybe with some front suspension upgrades (kmember, coil overs, and whatever else) you may have enough room for those headers (which were designed to fit under a pickup). i have personally seen a 5.4 sohc in a 01 GT. it had stock exhaust (5.4 exhaust that is) and it fit in the stock suspension fine, but the guy was having trouble finding headers to fit.
Old Aug 30, 2006 | 03:11 PM
MuscleOwnzRice's Avatar
MuscleOwnzRice
99% sure its forged, svt has a nack for doing some smart stuff to the bottom ends of their engines.
Old Aug 30, 2006 | 05:53 PM
yeayea0's Avatar
yeayea0
just curious....why do you want to upgrade? you can do a whole hell of a lot with those lil 4.6's
Old Aug 31, 2006 | 12:42 AM
David_K's Avatar
David_K
lightning is sohc. BTW youd have to get a navigator motor a complete 03 cobra blower setup and some RR adapter plates.
Old Aug 31, 2006 | 12:43 AM
David_K's Avatar
David_K
youd also have to cut a hole in your hood and let the blower stick out. that or get a 6" cowl which would look totally gay. a blower sticking out of the hood would look cooler
Old Aug 31, 2006 | 01:22 PM
drdarkman's Avatar
drdarkman
ORIGINAL: yeayea0
in my exp from what i know about engines is that there is no substitute for displacement. sometimes the bigger the better. and i would feel more comfortable is i was throwing 650-700hp at and engine with maybe a shot of giggle gas.
jwog666
Dec 27, 2021 08:09 PM
vargas
Jun 17, 2017 12:17 PM
guitarman376
Oct 11, 2015 01:47 AM
rksnow1
Sep 14, 2015 08:46 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
