SVT Forums
clutch knocking
Old Dec 4, 2006 | 11:17 PM
Mr_Cobra's Avatar
Mr_Cobra
Default clutch knocking
When i was coming home from work today, when i pushed the clutch in it started making a loud knocking sound and i felt a vibration on pedal. then it would go away for a while and come back. I did notice it seemed to do it if the RPMs were at 4k or higher. what is causing this?
Old Dec 5, 2006 | 12:08 AM
JamesTronix's Avatar
JamesTronix
Default RE: clutch knocking
Throw-out bearing is about to go out.
Old Dec 5, 2006 | 03:13 PM
MuscleOwnzRice's Avatar
MuscleOwnzRice
+1
Old Dec 5, 2006 | 10:42 PM
Mr_Cobra's Avatar
Mr_Cobra
whats the throw out bearing and is it an easy fix? I have to go to work tomorrow is this something i should not drive or if i take it easy i can get by for a couple days?
Old Dec 7, 2006 | 01:59 PM
MuscleOwnzRice
ya you probably could, it shouldnt go out right away but how long has it been doing that? Get it fixed this weekend would probably be the best idea
Old Dec 9, 2006 | 12:17 PM
svt99redcobra's Avatar
svt99redcobra
Not so fast on the throwout bearing. My cobra was doing the same thing and it was the metal sleave around the output shaft. The shaft that the throwout bearing mounts on. It was broken from the tranny. It was $800.00 to fix. But if you paying someone do take out the tranny. Its well worth it to buy a new clutch since you dont take down the tranny all the time. This would be a great time for a aluminum flywheel and heavy duty clutch.
Old Dec 12, 2006 | 11:52 PM
Mr_Cobra's Avatar
Mr_Cobra
I took my car in today and you were right it was the throwout bearing. the guy at the dealership told me that the 03/04 cobra throwout bearing was ****ty and if you had problems with it they would replace it even if your warrenty is up
Old Dec 14, 2006 | 06:00 PM
svt99redcobra
Ok im wrong again
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
