SVT Forums
through out bearing
Old May 14, 2007 | 04:43 PM
Dssr's Avatar
Dssr
Default through out bearing
Need some help I have a sqeal like a belt rubbing but when i step on the clutch it stops, question is there any adjustment o0nj the the bearing or do I need to replace the clutch, pressure plate, flywheel and bearing to stop this. any and ALL help is greatly appriciated.
Old May 14, 2007 | 09:58 PM
tazzracing1's Avatar
tazzracing1
Default RE: through out bearing
Nope no adjustments and if its squeeling it is time to think of replacing the setup. But you maybe luck and get away with just the bearing but if it was me I would do everything.
Old May 15, 2007 | 04:45 PM
spray175's Avatar
spray175
Get a freeplay kit from ldc chicago. The squealing is the tob riding on the pressure plate. That will make it stop squealing and you could also get a firewall adjuster and quadrant.
Old May 15, 2007 | 06:27 PM
arcticman37's Avatar
arcticman37
IMO it would be best to replace the entire setup excluding the fly wheel if its in good enough shape to be resurfaced if not I would replace that as well.
Old May 15, 2007 | 09:32 PM
Dssr's Avatar
Dssr
yea thats what I think, it's only got 42K on it might try the freeplay kit first. hey thanks for all the help
Old May 16, 2007 | 04:04 PM
spray175's Avatar
spray175
The kit is only 16.95, its a cheap fix. Just because your clutch is chirping doesnt mean its bad.
Old May 21, 2007 | 10:47 PM
Dssr's Avatar
Dssr
hey it worked simple made4 it fell like a new one. Again thanks for the help
6bangr
Feb 15, 2016 07:40 AM
KingRando
Oct 2, 2015 08:06 AM
allenmaty
Sep 24, 2015 09:17 AM
Offendant
Sep 23, 2015 07:21 PM
ccdguy
Sep 19, 2015 05:20 PM
