HELP!!!! Brakes, Turn signals, and Blinkers out.
RE: HELP!!!! Brakes, Turn signals, and Blinkers out.
Ok, so I checked the fuses again and I found where the turn signals, brake lights, and hazards are, but the fuses are fine. I replaced the bulbs in the brakes, hazards, and turn signals but still not working. What do I check now? I was told to check the switch that you turn the signals, wipers, and high beams on with, but about 2 months ago I replaced that with a new but used switch(if you know what I mean). Should I replace the switch with a brand new one or check something else that Im missing?[/align]
Ok, so I learned that the brakes and turn signals and hazards are two different fuses. I replaced to the fuses to see what would happen and I still have nothing with NEW fuses. What the ***! Im thinking its the multiswitch, but like I said, I replaced that about 2 months ago. WHAT AM I MISSING???????
