SVT Forums
P0153: What could cause this code to come up?
Old Jun 23, 2007 | 02:34 AM
keanbe50's Avatar
keanbe50
Default P0153: What could cause this code to come up?
P0153: HO2S Sensor Circuit Slow Response.
I have replaced all theO2 sensors and put the stock C.A.I. back on the car. I can't smog my car cause the tests that I put the car against at work showed that the EVAP, Secondary Air System, and EGR test were failed but the OxygonSenor and OxygenHeater test passed. What could cause this?
Old Jun 25, 2007 | 05:57 PM
AllVenom's Avatar
AllVenom
Default RE: P0153: What could cause this code to come up?
Do you have a tune?
Old Jun 30, 2007 | 11:02 PM
silver gt's Avatar
silver gt
had the same problem,you need to use factory 02 sensors,tried bosch&standard neither cleared code,tried Ford sensor problem solved. J-wiz
Old Jul 3, 2007 | 01:19 AM
klarkent42's Avatar
klarkent42
A code P0153 may mean that one or more of the following has happened:
[ul][*]The oxygen sensor is faulty[*]The wiring to the sensor is broken / frayed[*]There is an exhaust leak[/ul]
You may want to take a thorough look around, make sure everything is in tact.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
