SVT Forums
underdrive pullys
Old Jun 30, 2007 | 03:45 AM
97blackcobra's Avatar
97blackcobra
Default underdrive pullys
Has anyone put underdrive pullys on a 96-98 cobra? I tried today and when i got to the dampener I could not get the center bolt off. Is it a reverse threded bolt? If anyone has done this upgrade any imput would be greatly appreciated
Old Jul 1, 2007 | 04:28 AM
97blackcobra
Default RE: underdrive pullys
anyone??????
Old Jul 2, 2007 | 10:10 PM
98_cobra's Avatar
98_cobra
I'm pretty sure i got mine off but using a torque wrench. However after that i couldnt get the bolts that are used with the harmonic ballancer to fit into the pulley. Try fitting your bolts into the pulley and let me know if yours fit or not.
Old Jul 4, 2007 | 02:20 PM
mustang_mike13's Avatar
mustang_mike13
dude!!! i just did this the ither day on my 97. i did it the easy way. i pulled my radiator and got a impact wrech on it. that the only way you will get un less you put a screw driver in you stater and flywheel teeth. then you will need a 3 point pully puller to get it off. o and dont forget to take the washer off after you take the bolt off or the pully puller wont work.
Old Jul 5, 2007 | 11:33 PM
michael12203's Avatar
michael12203
put your car in gear and try it. a couple of hard pulls with a breaker bar and it got mine, i can tell a big difference ith them.
ctgreddy
Sep 20, 2015 08:35 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
WDScott
Aug 17, 2015 06:38 AM
skatepony
Jul 30, 2003 10:12 PM
