SVT Forums
Transmission fluid?
Old Oct 14, 2007 | 09:46 AM
StylinM6s's Avatar
StylinM6s
Default Transmission fluid?
Hi everyone, I'm confused as to what kind of tranny fluid I need. I have a 1998 Cobra that has the T-45 5-speed tranny in it and I would like to go synthetic. In my Haynes Repair manual it says it's recommended to go with Mercon automatic transmission fluid. Does that mean I need to get the Max ATF (royal purple) or because I've read some threads, some have gone with the Synchromax. It says the synchromax is for manual transmissions so I'm just really confused here. Also it says the capacity is 6.6 pints so 3.3 quarts is correct right?[/align][/align]Basically what I'm asking is:[/align][/align]1) What kind of transmission fluid should I go with from royal purple?[/align]2) Is 3.3 quarts the correct amount of fluid?[/align]
Old Oct 14, 2007 | 10:09 AM
5speedstang's Avatar
5speedstang
Default RE: Transmission fluid?
i just did mine and put ams oil synthetic in and it works wonders. i only had 20k on the trans but i still wanted to do it just to do it and i could tell a big differnce. my buddy put redline d4 in his and he said he felt a big differnce. he got his on ebay for $44 shiped 4 qts to his house. i paid 10 a qt so your lookin at the same price.
Old Oct 14, 2007 | 10:15 AM
97targa's Avatar
97targa
3.3qts is correct, some go a little bit less to help with easment of shifting. I need to let a little out of mine as well. I used Mobil 1 synthetic, so I'm unsure what you need for Royal Purple. I was told to stay away from that stuff for the tranny's. I went with Mercon V, Mobil changed their fluids about year ago and combined a few diff. old fluids together. You can use the Mobil 1 ATF for Dextron II, III, Mercon, Mercon V.
Old Oct 14, 2007 | 10:54 AM
StylinM6s's Avatar
StylinM6s
Yeah I see it on mobil1's website. The Mobil 1 Sythetic ATF for Dexron III, Dexron IIIE, Dexron III-H, Mercon, Mercon V looks to be exactly the match for our trannys. And all my local auto parts stores don't carry royal purple tranny fluids so I should be able to get mobil1. I'm actually gonna go to national auto stores now to get it.
Old Oct 14, 2007 | 05:16 PM
xx9gt6xx's Avatar
xx9gt6xx
ORIGINAL: 5speedstang
I am that buddy, lol. I noticed a good difference w/ the Redline D4 ATF but I think if you go w/ any synthetic fluid you'll see a huge difference in the smoothness of your shifts and stuff...
Old Oct 14, 2007 | 05:29 PM
StylinM6s's Avatar
StylinM6s
Thanks man, yeah i got 4 quarts of the mobil1 synthetic Max ATF. I'll have it changed the same time I'll get my exhaust installed since it'll be on a lift anyway
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 25, 2015 06:42 PM
