SVT Forums
please help
Old Oct 31, 2007 | 12:18 PM
SN8KBIT2004's Avatar
SN8KBIT2004
Default please help
I recently jumped ship(I HAD a 2002 Z28)and purchased a 2004 cobra. The car is a 1 owner and has a 3.10" upper pulley and a 90mm idler pulley. But in my glovebox there is a grey wire about 18" long and on the end of this wire is a dial that turns from 0-7, when it is set on 0 or 4 the car will crank up and run just fine, when it is on 4 the fanscut off.But when it is on 1-3 or 5-7 the car will do nothing but turn over. Does anybody have a clue on what this may be?? Thanks for your help, if you can help.
Old Oct 31, 2007 | 12:51 PM
mfj's Avatar
mfj
Banned
Default RE: please help
this is a switch to ur chip. keep it on 0!!! that is where ur "tune" is stored... the other numbers act as a kill switch when tunes aren't stored on there..
Old Oct 31, 2007 | 02:42 PM
SN8KBIT2004
So if I want to upgrade to a smaller pulley or do any other mods, how willI tune for it?? The cardoes not havea handheld tuner or anything, just the dial.
Old Oct 31, 2007 | 03:01 PM
AJ06GT's Avatar
AJ06GT
ORIGINAL: SN8KBIT2004
You can't by yourself. You have a chip that has multiple banks on it. When you get a dyno tune, they can flash the tune to one of the banks, then when you switch to that number, you're using that tune.
Old Oct 31, 2007 | 03:29 PM
mfj's Avatar
mfj
Banned
yeah, that cord is connected to the aftermarket chip u have in ur ecu. it is located behind the plastic panel where the passengers's right foot would be
Old Oct 31, 2007 | 04:02 PM
mills281e's Avatar
mills281e
Find out from the previous owner what tunes he has saved to the chip right now. May have one for everyday driving, a hot tune, etc.... You would be better served by knowing which setting to put it on rather than switching numbers blindly .
Old Oct 31, 2007 | 06:06 PM
mfj's Avatar
mfj
Banned
but by the default safe tune is always put to 0 by tuners.
Old Nov 1, 2007 | 09:30 AM
SN8KBIT2004
aight thanks for your help.
