SVT Forums
Throttle position sensor
Old Nov 5, 2007 | 10:56 PM
ZO6AINTPOOP's Avatar
ZO6AINTPOOP
Default Throttle position sensor
I Just purchased aAcufab Single Blade Throttle Body and I took my TPS of the stock throttlebody and put it on my new one and now my car is Idling high how do you set the TPS so that it will idle right? And one other thing is if anyone that has used a acufab does it shorten the pedal cable to cause it to be shorter?
Old Nov 5, 2007 | 11:28 PM
mfj's Avatar
mfj
Banned
Default RE: Throttle position sensor
its not the TPS thats causing u to idle high. screw the adjustment on the bottom of the tb to fix it. because the throttle body blade is letting in too much air at idle
Old Nov 5, 2007 | 11:31 PM
mfj's Avatar
mfj
Banned
also might want to try resettin ur computer so it can adjust to ur tb... just a thought...
Old Nov 5, 2007 | 11:55 PM
97targa's Avatar
97targa
ORIGINAL: mfj
+1 Although when I pulled my TPS sensor off my stock t/b and put it right back on my idle went high too. No codes or anything and had to actually buy an aftermarket one so I could oval out the holes to be able to turn it enough for the idle to drop. That was a temp fix until I got a new motor..lol
I would unplug the battery overnight and let the computer relearn itself. Hopefully it will work for you.
Old Nov 6, 2007 | 04:49 PM
slithersvt's Avatar
slithersvt
Had the same problem with a BBK on my 01 Cobra. After much work and talk with BBK I discovered the blades of the throttle body are too large for the intake. The blades of the throttle body were getting hung on the inside of the intake allowing too much air and increasingthe idle. I had the intake ports bored to match the size of the blades on the throttle body and it fixed the problem.
Old Nov 6, 2007 | 06:58 PM
spray175's Avatar
spray175
The tps has to be within a certain voltage when you put it back in. I think its .98-1.0 something like that.
Old Nov 7, 2007 | 10:50 PM
97targa's Avatar
97targa
ORIGINAL: spray175
This is on the 5.0L fox bodies where it's adjustable. If there is a problem with the voltage that would mean a computer malfunction where it has learned a diff curve because of too much flow.
Old Nov 8, 2007 | 05:31 PM
spray175's Avatar
spray175
Its for our cars as well. 03-04 cobras need to be at that certain voltage.
Old Nov 8, 2007 | 05:33 PM
spray175's Avatar
spray175
http://www.accufabracing.com/article_1.htm
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
