SVT Forums
Supercharger swap?
Old Dec 22, 2007 | 08:13 PM
kocheronya's Avatar
kocheronya
Default Supercharger swap?
I have an 03 with the stock eaton, I want more when I get back from deployment but dont wanna go too crazy.
I would like to go with a whipple but dont know what all needs to be done. Fuel system? Will it be okay with the stock heads, cams? How much??
Thanks!
Old Dec 22, 2007 | 10:52 PM
Blownsvt's Avatar
Blownsvt
Default RE: Supercharger swap?
heads and cams will be fine, you will need different plugs htough. you will want to get 60# injectors and a boost a pump in the way of fuel system upgrades. you will need a mafia at least as well. if you go with a 2.3 whipple which go for about 3200 i would guesstimate a touch over 4k if you do all the work your slef and don't get anyhting other than what i mentioned.
Old Dec 23, 2007 | 09:28 AM
flyin_hawaiin's Avatar
flyin_hawaiin
60lbs inj, bap, and mafia / or BA2400 MAF... along with a tuner... then, depending on your boost and aggressiveness of the tune, you should see 550-600rwhp on 93octane! I do this setup about 2-3 times a week LOL
Old Dec 23, 2007 | 10:29 AM
2k6silvergt's Avatar
2k6silvergt
You can actually get the black 2.3 whipple for about $2900 shipped. Give Steve over at Tousley Ford a call that is who gave me that quote.
Old Dec 23, 2007 | 12:23 PM
Blownsvt's Avatar
Blownsvt
sorry the 3200 is for a polished one not the standard black.
Old Dec 23, 2007 | 08:53 PM
kocheronya's Avatar
kocheronya
flyin_hawaiin
Date 12/23/2007 7:28:15 AM
Okay, Say I get all this, what kind of price am I looking at for the install and the tune? I already have the SCT.
Old Dec 24, 2007 | 10:39 AM
xxkazp3rxx's Avatar
xxkazp3rxx
For the whipple.. they gave you really what you'll need to get it to run but you're missing a few things still...
SUSPENSION.. you will need to lock down the IRS, or swap it for a straight rear axle... Definatly look at that, or you will blow your stock IRS eventually...
COOLING MODS: You definatly want to upgrade your heat exchanger, get a head cooling mod, radiator, and tstat...
One more little side note: I would not go with the cam package, a lot of money for little reward. Also, most guys don't go the head route either - I mean yeah our heads kinda suck - but unless you're tearing down the motor and going to be tracking it everyday - that's another thing where you probably won't get much help from. If you just want a low-mid 600rwhp Terminator get the whipple, and your cooling mods and be done with it. Just don't do anything stupid - the heads/cams you will spend a ton of money on and probably won't get much of a reward - might as well get a twin or a HUGE single turbo for the same money.
Old Dec 24, 2007 | 11:13 PM
flyin_hawaiin
ORIGINAL: kocheronya
flyin_hawaiin
where ya located??
Old Dec 26, 2007 | 12:43 AM
kocheronya's Avatar
kocheronya
I'm stationed at Pope AFB. Fayetteville, NC
Old Dec 26, 2007 | 10:44 AM
flyin_hawaiin
flyin_hawaiin
I dont know what people in your neck of the woods will charge ya for the install and tune, but i can tell you that your combination is EXTREMELY common and most reputable tuners could do that via mailorder.. I have done it a number of times... I could also supply ya with inj/maf/mafia...
thanks
