car sputters in high gear.
RE: car sputters in high gear.
WELL, CHANGED THE COIL PACKS AND PLUGS DIDN'T HELP. i HAD TO ORDER SOME NEW PLUR WIRES LAST NIGHT FROM ADVANCE AUTO THAT WILL BE HERE THIS MORNING. AFTER WORK I WILL BE PUTTING THEM ON. HOW LONG DOES IT TAKE TO TAKE OUT YOUR IMRC AND HOW HARD IS IT.
ORIGINAL: tjenkins8686
what about spraying some carb cleaner into the throttle bodie would that clean it out any. I hope its the wires. If it was the fuel filter or fuel pump, wouldthe sputteringnot get worse at a higher speed? btw thanks for everyones help. It feels like its just cutting out at wot. The car idles perfectly fine and when you rev it up its perfectly normal.
spraying carb cleaner or seafoam into your intake would clean up a little but not as good as takinging it apart and fuel injector cleaner wont help because the secondary ports dont really get sprayed by the fuel injector.Remember a clean engine is a happy engine It really isnt that hard it will take a lot of carb cleaner though 6 bottles to be exact, and a tooth brush or two.(Im not joking )
ShaneB26154
35
03-04-2021 04:05 AM
MEISTERSNFB
03-31-2020 07:50 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
