SVT Forums
Oil Pressure
Old Feb 6, 2008 | 04:57 PM
nebiag's Avatar
nebiag
Default Oil Pressure
Hi, I have a 1997 Cobra and i have a problem. When I am above 3-4 thousand RPM and i am flooring it my oil pressure go's from the middle to the bottom of low almost at Zero. I instantly stoped but when i restarted it which probly wasnt the greatest thing it was back in the middle of the gauge. But again when i am on the throttle the pressure drops and then when i lay off it gos to the middle. Has anyone ever had this happen or could it be a gauge or the oil pump.
Thanks
Old Feb 6, 2008 | 08:39 PM
codradude's Avatar
codradude
Default RE: Oil Pressure
You don't mention oil level, but I assume your crankcase is full. You might have clogged passages in the heads that is not allowing the oil to drain back to the pan fast enough. You also could have a faulty pressure regulating valve, a bad sensor, or a loose connection somewhere.
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
wraith777
Sep 28, 2015 10:49 AM
ccdguy
Sep 19, 2015 05:20 PM
SteelerNation82
Sep 16, 2015 07:11 AM
