SVT Forums
Question about 99 cobra
Old Feb 9, 2008 | 06:16 AM
DrDeaths01GT's Avatar
DrDeaths01GT
Default Question about 99 cobra
I was reading a few posts and saw where the 99's were recalled for being underpowered? I thought these cars came with 320 hp? (290 at the wheels?) If this was true, what caused the power loss? Just curious in case I want to buy one and I want to know my facts.
Old Feb 10, 2008 | 01:27 AM
01snake's Avatar
01snake
Default RE: Question about 99 cobra
99's without fix (recall) came with 305hp instead of the 320hp. there is no way they put 290rwhp. my 01 cobra stock put 277rwhp and that was the correct 320hp. so the 99's prolly layed ~265ish rwhp stock.
i believe the problem was in the intake, throttle body, and exhaust
Old Feb 10, 2008 | 08:19 AM
OzzDOA's Avatar
OzzDOA
The 99's were underpowered from the factory. The recall, known as "the fix", replaced the intake manifold, flashed the ECM, put a different idler pulley on and replaced the cat-back. To know if you have the fix or not you can look at the intake manifold and on the front driver's side you should have a green or yellow dot. You can also check by using the VIN and seeing if there are any outstanding recalls. 99.99999% of the '99 Cobras I've seen has had the fix.
Nov 10, 2015 11:39 AM
Ipaman
Sep 22, 2015 07:01 AM
04stangman
Sep 17, 2015 01:45 PM
Sparks_88
Sep 8, 2015 01:06 PM
