SVT Forums
Sustained high speeds
Old Mar 17, 2008 | 04:34 PM
ride_maine's Avatar
ride_maine
Default RE: Sustained high speeds
Why turn that many rpm's if you dont have too? Gears are a cheap way to insure your new, expensive shortblock will last a long time. WIth the kb especially, you'll have more than enough power to chug along at 120 at only 3 grand. Take everyones advice, and good luck on the project.
Old Mar 17, 2008 | 11:18 PM
Ehmark's Avatar
Ehmark
Thanks for the advice guys In a year or so Ill tell you all how it goes; )
Old Mar 18, 2008 | 09:42 AM
RuffCat's Avatar
RuffCat
ORIGINAL: Ehmark
I am not going to have to be at 120 for too long as Ive figured out .A friend of mine has actually done it before and he says I have to average about 95 to win for the class I want to enter I do not have the prerequisites to do any of the other groups. I will only have to be at really high speeds for only a few minutes to componsate for the narrows.120 is at just under 5000 revs with my current transmission and with the t56 It should be closer to 4000 rpms.That should be in the acceptable range with a good radiator and the EVEN FLOW right?
You will be at 4600rpms with the T45 in 5th gear and 120mph. The T56 will drop you a litle over 300rpms, not 1,000rpms like you think. You will be at 4250rpms or so with the T56. The reason for this is because the T45 has a .68 overdive gear and the T56 only has a .62 overdrive gear for 6th. Not that much difference. The T56 makes you just shift faster which is what people do not realize. It does give you that little bit of drop in roms though, but not really enough to show for. For the average speed of 95mph with your set-up will run you at 3650rpms
Old Mar 18, 2008 | 05:49 PM
Ehmark's Avatar
Ehmark
I was going to go with viper spec t56 6th gear is .52 not .62.
CS2007
Jun 25, 2019 09:45 PM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
BeatnikFink
Oct 1, 2015 08:00 PM
Drastang
Sep 30, 2015 03:48 AM
