SVT Forums
2001 Cobra Idle Issues
Old Mar 26, 2008 | 12:04 AM
dhriza's Avatar
dhriza
Default 2001 Cobra Idle Issues
Hoping someone can offer some advice....I have a 2001 cobra that has the following mods...
-BBK CAI
-BBK Throttle Body
-BBK long tube
-BBK midpip
-Bassanicatback
-Diablosport Handheld
That is it for the mods...when my car warms up....after about 10 minutes or more in traffic especially it won't idle right. I push in the clutch and the RPM will climb to 2500 I have to bump the gas....(rev it pretty higg) to get the idle to come back down. The TPS has been replaced and the shop I take it to in AZ hasn't been able to figure it out yet. They keep wanting to replace the same damn parts. Please...I need advice...luv my car but this is getting to be a pain in the @$$.
Thank You-
David Riza
Old Mar 26, 2008 | 02:00 AM
Martel's Avatar
Martel
Default RE: 2001 Cobra Idle Issues
This guy has a similar issue, check out his threads.
https://mustangforums.com/m_4757512/...tm.htm#4757512
https://mustangforums.com/m_4757775/...tm.htm#4757775
https://mustangforums.com/m_4788877/...tm.htm#4788877
https://mustangforums.com/m_4793192/tm.htm
https://mustangforums.com/m_4806908/tm.htm
Old Mar 29, 2008 | 08:01 PM
dhriza's Avatar
dhriza
Thanks for the response...does anyone know if a stock IAC works with a BBK twin 65mm throttle body....could this be an issue?
Old Mar 30, 2008 | 09:25 PM
darcnytemare's Avatar
darcnytemare
lol....i have this same problem with my 99 cobra. once i get into 2nd gear around 2K rpms i mash the gas real quick to loosen it up. had the same problem every mechanic can't figure it out.
Good deal though with those links.
Old Mar 31, 2008 | 02:05 PM
Ellik's Avatar
Ellik
lose the throttle body, its not doing anything for you. Go back to stock.
Old Mar 31, 2008 | 03:22 PM
baino's Avatar
baino
the 01s have a touchy intake setup. for some reason the computer doesnt much care for throttle bodies or fabricated spacers.
Old Apr 2, 2008 | 01:10 PM
01BlueCobraVert's Avatar
01BlueCobraVert
Put the stock throttlebody back on. Problem solved. I have only ever heard bad things about them. Everyone seems to have the same issue
Old Apr 7, 2008 | 06:37 PM
96CsTaNg's Avatar
96CsTaNg
By chance does the idle run high when the ac is running? if so that might mean that you need to have you ac recharged. The samething is going on with my car. Im going to have the ac recharged soon. Let me know if you try that..
Old Apr 7, 2008 | 06:40 PM
96CsTaNg's Avatar
96CsTaNg
Sorry thats when you push your clutch in. They say that the clutch will over comp for the ac. But yet I have no idea. But I going to try it.
Old Apr 8, 2008 | 10:32 AM
meechuacon's Avatar
meechuacon
Probably a bad IAC valve.
2007StangV6
Jan 28, 2016 06:09 PM
Nov 10, 2015 11:39 AM
MusicCity615
Sep 12, 2015 07:05 AM
Sparks_88
Sep 8, 2015 01:06 PM
Emblazoned
Sep 3, 2015 10:45 PM
