SVT Forums
Noisy Gears
Old Apr 21, 2008 | 11:16 AM
robbylozzi's Avatar
robbylozzi
Default Noisy Gears
I just got an 03 cobra after i got out of the army. the gears in the tranny are noisy....i took it in to get it looked at and they said that the gears are just big and noisy...i believe that part, however, there is a certaing noise that happens at low rpms....its like a clank when you let off the gas and then accelerate again. kind of feels like a tranny mount is broke or something??? the dealership says its nothing...??
what do you guys think...do you have the same noise?
Old Apr 21, 2008 | 08:10 PM
RuffCat's Avatar
RuffCat
Default RE: Noisy Gears
tranny houldn't be making any noise. The clank you refer to is most likely the u-joints. They are probably worn. If those aren't the problem then I would have to go right to the backlash on the ring and pinion ar worn. Prob just the u-joints. Change your trans fluid and if you have an aftermarket shifter make sure it's adjusted properly. Too far into gear will cause noise and not far enough into a gear will cause same noise. Good luck
Old Apr 22, 2008 | 08:02 AM
robbylozzi's Avatar
robbylozzi
Thanks Brotha
Old Apr 24, 2011 | 11:28 PM
scottyb's Avatar
scottyb
i know this is an old topic, but i was wondering if anyone else has had this issue? i was going to message robbylozzi, but it doesnt look like hes been on in a while. im currently doing searches on this topic but thought id throw it on the message boards again to see if anyone knows.
Old Apr 25, 2011 | 05:20 AM
uberstang1's Avatar
uberstang1
Chupacabra
Check U-Joints on DS.
Old Apr 25, 2011 | 05:32 AM
Blackvenom01's Avatar
Blackvenom01
both my tranny and rearend make sounds and thats how i baught it...both the rearend and tranny are built like crazy its just how they put it together..it was prolly shimmed wrong causing some noise...i wouldnt worry to much unless you can hear yourself think then yes take it in before it blows lol
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
