SVT Forums
PORTED HEADS!!
Old Apr 27, 2008 | 05:59 PM
Ehmark's Avatar
Ehmark
Default PORTED HEADS!!
YAY I just bought ported bare B series heads on ebay for $170.Now all ive got to do is save up for the mmr 5.0 shortblock and fr500 cams.Then comes the t-56 and vortech. LOL ive got a long long way to go. But its a start at least.
Old Apr 29, 2008 | 09:43 AM
RuffCat's Avatar
RuffCat
Default RE: PORTED HEADS!!
Who ported them? If it was done by hand you might want to send them out and have them put on a flow bench. B-series heads are overly large to begin with and don't really need porting..IMO The problem with those haeds was they had too big of ports to begin with. That's why Ford came up with the "Fixit" imrc plates. Thos eheads need more work as far as valves and cams than opening up the actual ports themselves, Now, it is wise to contour the edges where air gets restiicted between the ledges of the primaries and secondaries. That helps out a great deal but as far as taking out a bunch of metal on the inside....not good. If the insides are super shiny and smooth, you'll want to grab a dremel and roughen up the insides a bit to help with the air mixture and so fuel and oil won't build up on the walls.
Also, I have 98 SVT Composite IMRC plates for sale if you were interested. They have the larger ports than the aluminum one's and are much easier to convert to deletes than aluminum one's. Much better for blower app's. PM me if interested. I can make them as deletes for $50. I'm askin $175 shipped as they are. They are MINT!!! Gaskets and all.
Old Apr 29, 2008 | 04:50 PM
Ehmark's Avatar
Ehmark
Nah ive got my own imrc deletes. Thanks for the offer. I have no clue how well that they have been ported I will put up pictures when they get here. Hopefully they were ported by someone who knew they already have huge ports and just focused on the bowl area and the exhaust ports.Either way this is going to be with my forged block and eventually a vortech so it should be fine.If the port job sucks ill just get a local shop to fix them up.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Drastang
Sep 30, 2015 03:48 AM
