SVT Forums
tires
Old May 3, 2008 | 10:37 PM
2k6silvergt's Avatar
2k6silvergt
Default tires
Looking at getting a set of nitto dr's for the car. Will 315's fit on my stock rims? I know the nittos are suppose to run smaller than the bfg dr's or et streets.
Old May 3, 2008 | 10:41 PM
2k1gt's Avatar
2k1gt
Default RE: tires
I have heard of people doing it so yes, it will fit.
Old May 4, 2008 | 01:00 AM
562cobra's Avatar
562cobra
Default RE: tires
you'll have problems fitting 315's if you still have the irs.
later.
Old May 4, 2008 | 07:52 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: tires
You didn't mention the wheel width you are running. Unless you have 10.5" (or wider), 315's are NOT rated to fit (none I have seen anyway). I have heard of people running 315's on as small as a 9" rim, but is a bad idea, IMO.They would be a much better fit on 10"s, but would recommend you stay within the manufacturers specs as it will fit properly as well as not be a liability issue. Of course, as 526 mentioned, you can have fitment probs on IRS Cobra. You can run 10.5"s with spacers,as I do,but will require you to replace rear lug-bolts to accomodate them. Having IRS will introduce clearance issues I don't have, so you need to do some research.
A thread about 2 weeks back in SVT section addresses wide rims on IRS and has some usefull info, so seek it out
Old May 4, 2008 | 09:40 AM
2k6silvergt
Default RE: tires
Well I know tires like the 315 bfg dr's and the 315 et streets won't fit the stock 17x9 rims, but I have been told by many others that the nittos will since they run narrower. I know there a quite a bit of people who are actually running that setup and say they work well. And yes it is still the irs.
Old May 5, 2008 | 09:45 AM
mfj's Avatar
mfj
Banned
Default RE: tires
nitto 555R 315's will fit ur 9 inch rims... they bulge, but they DO fit
Old May 6, 2008 | 07:23 AM
2k6silvergt
Default RE: tires
ORIGINAL: mfj
Ya I actually saw them on stock cobra rims yesterday. I think I am just going to go ahead and get the 275's.
Old May 7, 2008 | 12:05 PM
bugpack28's Avatar
bugpack28
Default RE: tires
all the 315's fit the 9 inch rim including the Mickey Drag radials which are the widest! Ive had all of them on my factory 17 by 9 inch wheels. With braided brake lines you might have to check that they don't rubb but thats it.
Old May 7, 2008 | 12:07 PM
2k6silvergt
Default RE: tires
ORIGINAL: bugpack28
You are the first person I heard that from. Were you using spacers?
Old May 7, 2008 | 03:48 PM
jkimbell's Avatar
jkimbell
Default RE: tires
I am running 315/35 17 on the stock 17x9 wheel. They do bulge out and would fit better on a 10 inch wheel but I haven't had any clearance or other problems with them. This is actually my 2nd set of the Nittos
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
