SVT Forums
cobra stuck in third gear
Old May 12, 2008 | 06:28 PM
granny's Avatar
granny
Default cobra stuck in third gear
My buddies has an 03 cobra and this morning he was out driving it and it got stuck in gear and he could not shift it into any other gear . Has anyone else ran into this problem or might know whats wrong, and what route should he take to beef up the transmission to make it alot stronger thanks in advance
Old May 12, 2008 | 08:00 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: cobra stuck in third gear
Sounds like an issue I used to have with my Vega (yep, Chevy Vega ) Waaaaayyyyy back in my teen years. The Synchros used to go bad and would not come out of third gear. I was able to dis-engage with clutch, but could not go into any other gear. Happened several times as it was an Opal trans. The very first time, I took the trans out, and put in on work bench to check it out. It rolled over and popped out of third. I came tothe conclusion it was "jammed" by something and re-installed it again. Ireplaced it2 days later []
I don't know if yours has the same issue, but is same description. Can you see if anything mechanical is in the way of linkage?
Jazzer
Old May 12, 2008 | 08:17 PM
granny's Avatar
granny
not sure but i will call him and see what he says
Old May 12, 2008 | 09:07 PM
ponysnake99's Avatar
ponysnake99
Does your buddy have an aftermarket shifter? have you checked the set screws? He may have over shifted and damaged internals, but check the shifter and make sure its in correctly, because otherwise its a rebuild process. Damaging the t-56 takes some power/mistake, rebuilds or viper-spec trannys are good replacements. G-force transmissions sell upgrade kits to handle 900+ if he doesnt mind extra noise.
Nov 10, 2015 11:39 AM
musnicki
Sep 23, 2015 07:11 AM
rafotree
Sep 22, 2015 03:55 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sparks_88
Sep 8, 2015 01:06 PM
