Hi I kinda have had the same problem and it came down with it being in the intake. So if you try everything that everyone else said then you might want to take your car in and get the intake looked at. By the way have you checked if the car is throwing any codes out?
that corrosion isn't to bad, might want to get a new one though. also check your pcv valve,, sometimes that can do it. IS YOUR CHECK ENGINE LIGHT ON?? If so what code is it??
